Converting Cable Internet To WiFi?? - PC Repairs & Upgrades - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > PC Repairs & Upgrades
Old 06-20-2012, 08:50 AM   #1
Rewards Points: 274
Converting cable Internet to WiFi??
Currently I have cable internet coming into the house, connected to a cable modem, then a router to three PCs. I an happy with the set up but my wife bought this Nook thing (like a Kindle) for downloading books and reading. The thing is, this Nook, only connects through WiFi. There is no Ethernet connection.
I don't necessarily want to make all of my PCs WIFi, just have it available when she wants to DL another book to read. I understand all I need is a WIFi router. I would have the cable in to the cable modem, and a cable out split to the cable router and to the WiFi router, and that should be it????
I don't think I need to put a WiFi card in any of the PCs. Is that correct?
Thanks for your help.
polarzak is offline   Reply With Quote
Old 06-20-2012, 09:05 AM   #2
Rewards Points: 6,652
All you need is a WiFi router. It will have a four port switch for wired ethernet, and allow you also to do Wifi.
Old 06-20-2012, 10:59 AM   #3
Rewards Points: 274
Thanks for confirming my thoughts. Much appreciated.
Old 06-24-2012, 06:30 PM   #4
Too Short? Cut it Again!
Obviously, you would need wireless cards in PCs, laptops, or tablets you wanted to connect to the router via WiFi. Signal type needs to match but that should not be an issue. Positioning the router can sometimes be tricky but the range on them gets better and better.
Just a thought. If you have not priced wireless internet in awhile and it is available in your area? You might look into it. It is much cheaper and more reliable than cable here in the City. I get unlimited 4G wireless service through CLEAR, with no throttle down, for $45/month. I currently have a stick thing in the side of my laptop but want to switch to a hotspot. Theirs will let you connect six to eight devices. No contract but you have to buy the device for $100.
Old 06-24-2012, 06:41 PM   #5
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 12
I thought all modern modems sent out WIFI. I have ATT dsl and we have 2 puters wired 2 it and 4 laptops wireless. I bought a USB wireless card for one of the old desktops for about $14 so I didn't have to run a cable to a back bedroom.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 06-24-2012, 07:06 PM   #6
WiFi routers outsell non-wifi, so you tend to see more of them in the consumer market. Where as in the business market you see Access Points, repeaters, bridges for Wifi, not combo units.
Old 06-25-2012, 06:24 AM   #7
Rewards Points: 274
Thanks for the reply. Yes, I am aware I would need wireless cards in the PCs, but they are all wired and that is fine with me. It is just my wife's" Nook (like a Kindlel) can only use WiFi, I bought a wireless router with four ports, replaced my wired router, with it. Now I still have my wired PCs, and she has WiFi for downloading books to read. Works great, and the router was only $25.00.
Thanks to all.
Old 06-25-2012, 09:49 PM   #8
Rewards Points: 16
Thanks to all.
Make sure your internet connection is password-protected, or others will be able to use your service and you may be liable for what they do through your router.
If you had to enter a password when you connected you Nook to the router, then you should be all set. If not, look in the manual. Usually, it involves going to an administrator web page in your browser and changing the admin password - you should change two passwords: one for the admin web page, and the password you will use to connect to the router.
whiskers is offline   Reply With Quote
Installation of Thermal Cable RenoMom Flooring 1 07-18-2011 10:45 PM
slow....................internet RichyL PC Repairs & Upgrades 16 10-20-2009 08:57 AM
Underground service entrance cable requirements. kgt55 Electrical 9 06-22-2009 07:55 AM
No Signal From Tv Cable LJMSURG Electrical 17 10-11-2008 09:00 AM
Coaxial Cable Question bahaisamurai Home Theater 9 08-08-2007 03:54 PM
