Computer Build! - PC Repairs & Upgrades - Page 4 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > PC Repairs & Upgrades
Old 08-01-2014, 07:12 PM   #46
kwikfishron's Avatar
Rewards Points: 1,024
I just received a shipping conformation on one item I ordered. An anti static wrist strap, price...$1.84 with free shipping.
The seller is located in Hong Kong, the item is being shipped via Hong Kong Post and will arrive between 8/25 and 9/12.
How can anyone make any money on that?
kwikfishron is online now   Reply With Quote
Old 08-01-2014, 07:21 PM   #47
JOATMON
ddawg16's Avatar
Rewards Points: 2,142
For those wanting to know about SSD's vs HD's.....here is a pretty good write up..
http://www.pcmag.com/article2/0%2c28...04259%2c00.asp
Tidbit of note worthy mention...
As far as longevity goes, while it is true that SSDs wear out over time (each cell in a flash memory bank has a limited number of times it can be written and erased), thanks to TRIM technology built into SSDs that dynamically optimizes these read/write cycles, you're more likely to discard the system for obsolescence before you start running into read/write errors. The possible exceptions are high-end multimedia users like video editors who read and write data constantly, but those users will need the larger capacities of hard drives anyway. Hard drives will eventually wear out from constant use as well, since they use physical recording methods. Longevity is a wash when it's separated from travel and ruggedness concerns.
So.....This is why you want to use an HD for heavy data storage and the SSD for the OS and programs.
Old 08-01-2014, 08:19 PM   #48
Rewards Points: 402
Yeah, but the OS is constantly swapping to and from disks, mainly with page files or temp files, so that's why I wondered about longevity.
taylorjm is offline   Reply With Quote
Old 08-01-2014, 08:24 PM   #49
JOATMON
ddawg16's Avatar
That is why you want a lot of memory. It reduces/eliminates the page file swaps.
At 8G, the page file swap pretty much goes away unless you have a crap load of applications open at the same time.
Old 08-01-2014, 08:40 PM   #50
Rewards Points: 402
You still have to get the data from the drive to that 8gb of ram, which requires read/write requests, then the os will try and predict what files you are going to use and swap them to ram to increase speed, but it has to do that constantly. So the read/write requests are the same, but it seems faster since you aren't waiting for the data from the drive and taking it from ram instead.
Old 08-01-2014, 08:46 PM   #51
JOATMON
ddawg16's Avatar
You didn't read the info right....
You can read from SSD all you want without decreasing life.....it's the 'writes' that shorten the life.
If you have plenty of RAM...you're not swapping to disk (SSD)....so...life is good...
Old 08-01-2014, 08:51 PM   #52
Rewards Points: 402
"If you have plenty of RAM...you're not swapping to disk (SSD)....so...life is good..."
I will agree to disagree on this point.
Old 08-02-2014, 11:55 AM   #53
Rewards Points: 4,274
Page files can be moved to other drives. (In fact I don't even run with a page file anymore) All temp data files can be moved to other drives... mail... internet cache... etc, if you have a concern.
Bob Sanders is offline   Reply With Quote
Old 08-02-2014, 02:45 PM   #54
r0ckstarr's Avatar
Rewards Points: 2,064
Yep. Just do a search on how to set up a scratch disk.
The idea of using the SSD drives is very interesting. I might have to give it a test try and see what it can do. The only thing I wonder about is the failure rate and reliability. The reviews are all over the board, some say it's great, some say garbage and it died, but the same seems to happen with hard drives these days. The last time I bought 5 drives, 2 were doa.
Ive had a SSD in both of my computers for 2yrs now. One is used for office things. The other is for everything else (photography, digital design, games, etc..).. So far, no problems on either.
r0ckstarr is offline   Reply With Quote
Old 08-09-2014, 09:46 AM   #55
Computer Build (part 2)
So I got everything together and it booted right up. Loaded win7 on the ssd but I can't connect to the internet to load all of the updates.
I have it plugged in directly to the router, it ask for a username and password then it comes back with an error.
The diagnostics says "Install a driver for your network adapter" and "windows did not detect a properly installed network adapter. If you have a network adapter, you will need to re-install the driver."
Where do I get this driver?
Old 08-09-2014, 09:52 AM   #56
From another computer that has Internet connectivity search on the brand name of your network adapter and windows 7. Although most network adapters today are pretty generic except in high multi-port adapters. Trust the Microsoft site or manufactures site before third parties.
jimn01 is offline   Reply With Quote
Old 08-09-2014, 10:32 AM   #57
I got it working now, thanks.
Old 08-09-2014, 11:50 AM   #58
Next question.............I have the OS installed on a SSD. I have another HD I want to install everything else on but I am not showing that the second HD is even there looking in "computer". It only shows the SSD and the DVD.
When I re-boot and go into the bios it does show that the extra drive is there.
Old 08-09-2014, 12:18 PM   #59
It also shows the extra HD in device manager but not in "My Computer".
How do I set the second drive as the default so the ssd does nothing more than hold the OS?
Old 08-10-2014, 08:37 AM   #60
Right click on the drive in device manager. Make sure it indicates it's working correctly. I wouldn't think you would need any special driver.
As far as redirecting your pictures, documents etc. right click on the library folder and select properties and change the location. Sear Microsoft.com for redirecting libraries widows 7 for more details.
When install programs, makes 2 directories on the second drive. Call one Program Files and the other Program Files(x86). We installing applications select these directories rather the ones on C:
Take the computer outside? gma2rjc Off Topic 9 08-09-2012 10:36 PM
Build up in cast iron pipe bend -> new high pressure toilet to fix? VTJeff99 Plumbing 3 02-09-2012 01:05 PM
How much more would it cost to build another story? reveriereptile Building & Construction 5 01-19-2012 10:51 PM
How do I build this sofft? swt99svt Building & Construction 7 01-17-2012 06:26 AM
High Tech Computer Desk nicksti Interior Decorating 0 11-20-2009 08:12 AM
