Beware Wifi Router WPS Vulnerability - PC Repairs & Upgrades - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > PC Repairs & Upgrades
Old 01-24-2012, 09:31 AM   #1
raylo32's Avatar
Rewards Points: 1,238
Beware wifi router WPS vulnerability
Affects almost every current wifi router. By the spec they must have WPS and have WPS enabled by default to be "wifi certified". And most (notably cisco/linksys) have no way to totally disable WPS. Supposedly they are "working on it" but they have known about this flaw for a long time so maybe not a good idea to hold one's breath.
http://www.smallnetbuilder.com/wirel...or-the-wps-fix
raylo32 is offline   Reply With Quote
Old 01-25-2012, 06:52 AM   #2
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
I have Tomato firmware flashed on all my routers. No built in WPS support.
Darkling Designs
poppameth is offline   Reply With Quote
Old 01-25-2012, 08:29 AM   #3
raylo32's Avatar
That or DD-WRT is about the only real solution until (if?) the mfgs develop fixes. But not many users have the skills to do this, especially the ones who would use WPS in the first place. And many routers are not supported by either.
Old 01-25-2012, 08:46 AM   #4
Ironlight's Avatar
You can also limit who can connect to your wireless network through individual MAC (machine access code) filtering. Basically you need to add the MAC address of all authorized devices to a list in your router. If a device is not listed, the router won't let it connect to your network regardless of whether it has the correct PIN or not. This is far more secure than WPA, and virtually every wireless router supports it these days.
Ironlight is offline   Reply With Quote
Old 01-25-2012, 01:04 PM   #5
raylo32's Avatar
MAC filtering isn't that robust these days since sniffing out MACs and spoofing is relatively easy with freely available tools. Not a bad idea though, but kind of like putting "the club" on your steering wheel. At best you only slow the bad guys down a few minutes. Better to keep them off the network altogether.
Old 04-02-2012, 11:23 PM   #6
Ravenworks's Avatar
Probally why Linksys/Cisco started offering their source code and now supports DD-WRT. You can download it right from their website.
Ravenworks is offline   Reply With Quote
router problem boman47k Networking 4 04-12-2011 07:07 PM
Router Advice diyheroe Carpentry 0 09-24-2010 10:09 AM
Router Table gmhammes Tools 8 06-27-2010 11:32 AM
Shutoff switch for custom Router Table. mfleming Electrical 14 11-13-2008 01:50 PM
router irwinbuilt Carpentry 5 01-20-2008 08:22 AM
