Beware Of Cheap USB Wall Chargers!! - PC Repairs & Upgrades - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > PC Repairs & Upgrades
Old 04-20-2013, 11:01 AM   #1
Rewards Points: 1,010
Beware of cheap USB wall chargers!!
Several weeks ago I woke up one night because my cell phone, which was charging next to my bed, was making weird noises. I looked at it and was stunned to see it was opening and closing apps at random! I kept touching the screen to stop it, and it wouldn't respond to anything I did. Next thing I knew it opened up my recent call history, picked a number and dialed it! (It was interesting trying to convince my gf I wasn't drunk dialing her at 1:30 in the morning). It finally stopped acting whacky when I yanked the charge cord out.
I later found out that the $5 USB wall charger I had just bought was the culprit. That night was the first night I plugged the phone into it. I did some research and found that apparently some cell phones (mine is a Droid Razr) are sensitive to the proper voltage coming from the charger, and if the charger isn't quite providing the right voltage, the phone can act up.
spaceman spif is offline   Reply With Quote
The Following User Says Thank You to spaceman spif For This Useful Post:
PaliBob (03-14-2014)
Old 04-20-2013, 12:15 PM   #2
GBrackins's Avatar
Rewards Points: 2,108
amazing, thanks for the post spif!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 04-20-2013, 12:56 PM   #3
Rewards Points: 33
Yep. My phone does that as well.
I've found it to be based on the outlet used as well. Where I work, I can't use certain outlets, even with the charger that came with my phone. Other outlets in the building and the outlets in my house are fine, however.
venator260 is offline   Reply With Quote
Old 04-25-2013, 07:16 AM   #4
Too Short? Cut it Again!
Just because the cords fit does not mean the voltage is correct. You should always check the output of the charger matches that the phone is set up to deal with.
It may not have been that the charger was cheap. Just outputting the wrong voltage.
We all do it I guess but it we might be better off charging with the device off!
Old 03-13-2014, 05:26 AM   #5
Thanks for sharing but i never go for cheap usb wall chargers....
joseph101 is offline   Reply With Quote
Old 03-13-2014, 05:33 AM   #6
Framing Contractor
Rewards Points: 118
We have been using the cheapie chargers for years. $5 instead of $30 is huge when you have 4 phones in the family. Never had any issues other than an occasional short life span of one charger.
sixeightten is offline   Reply With Quote
Old 03-13-2014, 10:17 AM   #7
Rewards Points: 736
While I agree with this in most cases, USB is supposed to be a standard 5v. Nothing in the USB form factor should be outputting a different voltage.
TheBobmanNH is offline   Reply With Quote
Old 03-23-2014, 10:36 AM   #8
I think of it like this, you get what you pay for.
mbender2004 is offline   Reply With Quote
Old 03-23-2014, 07:11 PM   #9
Mad Scientist
What causes this is usually EMI/RFI transmitted along the USB cable from a poorly filtered power supply. It screws with the phone's capacitance touch screen, making it think someone is touching it.
McSteve is offline   Reply With Quote
Old 03-30-2014, 06:52 AM   #10
r0ckstarr's Avatar
Rewards Points: 2,052
When my girlfriend used her Zune charger with her Android phone, her phone constantly rebooted itself.
r0ckstarr is offline   Reply With Quote
Retaining wall work-- what approach? emcelvaney Landscaping & Lawn Care 2 09-24-2012 07:49 PM
How to face a cinder block retaining wall with stone? CarrollY Concrete, Stone & Masonry 5 09-04-2012 12:26 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
