Battery Backup For Desk Top - PC Repairs & Upgrades - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > PC Repairs & Upgrades
Old 06-23-2015, 07:27 AM   #1
craig11152's Avatar
Rewards Points: 388
Battery backup for desk top
I'm an FNG here so if this has been covered I apologize. I did a brief search and didn't see anything.
I am needing/wanting a battery back up for my desk top. I don't need something that runs for hours, just long enough to shut down in a normal fashion if I lose power. If it had the "muscle to run for 10-15 minutes that would be a bonus. mostly when I lose power its for seconds, so mostly what I want is for my computer to not suddenly go dead in my 2 second power outage.
Any suggestions for a specific model or what I need to look for is appreciated.
craig11152 is offline   Reply With Quote
Old 06-23-2015, 09:32 AM   #2
Rewards Points: 2,212
What you are looking for is an UPS unit. It plugs in the wall then your computer and other stuff plugs into it.
mae-ling is offline   Reply With Quote
The Following User Says Thank You to mae-ling For This Useful Post:
craig11152 (06-23-2015)
Old 06-23-2015, 10:14 AM   #3
A UPS is rated in watts it can supply for a few minutes. Total up the wattage for your computer, monitor, your cable or DSL modem and any other network components and buy a UPS that can handle about 30% more than that. It's only going to run for a few minutes. I have mine start the shutdown after 2 minutes with no power. That gives me time to save files etc.
jimn01 is offline   Reply With Quote
The Following User Says Thank You to jimn01 For This Useful Post:
Old 06-23-2015, 10:49 AM   #4
craig11152's Avatar
Rewards Points: 388
Thanks. I run 2 monitors but don't really care about the modem. One monitor says 55 watts, one says 31.2 watts and the computer says 300 watts. So I assume I'm good with 400 watts? And I assume the more I spend the longer they stay on?
As I indicated my main concern is the occasional 2 second mystery outage DTE "blesses" me with.
Old 06-23-2015, 11:50 AM   #5
joed's Avatar
Rewards Points: 13,766
The UPS needs to be able to handle the total wattage of your system. If you want it to stay on longer then you need bigger batteries.
Old 06-23-2015, 01:20 PM   #6
Rewards Points: 46
You don't have to connect your monitors to the ups, as they don't have files to lose. I do on my setup, but I also have 2kw/h worth of capacity. (my system will run for about 1.5 hours on that) Usually when people here ask for a UPS, they aren't willing to spend a ton of money. Letting your screens die is one compromise. Set your computer to hibernate after 30sec or so, (depending on runtime) that why you won't lose any data if your power isn't restored in time.
Cheers!
supers05 is offline   Reply With Quote
The Following User Says Thank You to supers05 For This Useful Post:
MT Stringer (06-23-2015)
Old 06-23-2015, 01:39 PM   #7
MT Stringer's Avatar
Rewards Points: 254
Lots of choices from reasonable to expensive.
http://www.newegg.com/UPS/SubCategory/ID-72
Actually, the cost is pretty cheap when you consider what you might lose in a power dip. That's what we called it at work - anything less than three seconds. That is the way it is at my house, just a temporary interruption of power.
MT Stringer is offline   Reply With Quote
Old 06-24-2015, 05:49 AM   #8
craig11152's Avatar
Rewards Points: 388
thanks for all the advice and feedback gentleman (and/or ladies?)
I think I might get two. One to power the 300 watt computer and one to power the 2 monitors, which upon further review each are 45 watts not the 55 and 31.2 I indicated earlier.
Old 06-30-2015, 07:46 PM   #9
Work Hard, Play Harder
Rewards Points: 212
They will always come with a few pass-thru ports. You could do better financially with a single nicer one and plug one of the two monitors into one of the pass-thru ports.
You can also get one and monitor the load capacity, if you are near it consider a second one. Most of the newer ones have nice displays and a usb port - they can be set to simply safely shut down the computer for you.
coderguy is offline   Reply With Quote
Old 06-30-2015, 08:14 PM   #10
Rewards Points: 16
I wouldn't bother with getting a second UPS for your flat panels (FP). I have two FP's (24" and 19") hooked up to my UPS. When my power goes out and if I want to maximize my battery run time, I move any open windows in my smaller FP to the other FP and power off the smaller FP.
You may want to reconsider plugging your modem and router into the UPS. If you are in the middle of a project that is using the internet, you would want to finish that project before shutting down your system during an extended outage.
I'm using a 11 year old APC 750VA / 400 watt UPS. When this UPS was new I could get 45 minutes out of the battery using one 19" FP monitor, mini-tower, and modem. After 4 years my battery would last only 10 minutes. I replaced that battery in 2008 and this one is still going strong and I can get about 35 to 40 minutes out of it. Normal life of a UPS battery is 3 to 5 years...depending on the quality of your power and how long you run on the battery power during extended outage.
fuzzmanks is offline   Reply With Quote
The Following User Says Thank You to fuzzmanks For This Useful Post:
craig11152 (07-01-2015)
Old 07-01-2015, 08:58 AM   #11
craig11152's Avatar
Rewards Points: 388
I bought a unit at Costco last night for $99. A CyberPower with 810 Watts.
Got both monitors and computer hooked up now. It says I have about 40-50 minutes of run time. If I close out the internet and both monitors it jumps to a little less than 3 hours. Don't know how accurate those numbers really are.
Good point on the modem/router. But that is in another room and I will buy another UPS rather than rearrange things.
I day trade stocks and wouldn't want to lose my connection with an open trade.
99.9% of my power outages, which are rare, are 2-5 seconds, just long enough to have my computer go dead and have to reset the clock on the oven and microwave.
Don't look at me. I didn't vote for either one of them.
Old 07-22-2015, 02:48 PM   #12
Rewards Points: 32
Some models of UPS allow you to install software on your computer to gracefully shutdown when the battery is depleted. You'd have a usb cable included if your unit supported it.
kars85 is offline   Reply With Quote
Old 07-22-2015, 03:44 PM   #13
Rewards Points: 22
I've had a CyberPower 1350AVR for several years and it's great. I would get one bigger one instead of two. Mine can power my desktop and monitor, plus modem and router, and only uses about 10% of the capacity I think. If the power goes out, I turn off the computer and monitor and then the modem and router will run almost forever so we have wifi for our smart phones and laptop.
If you're not in a hurry, UPS usually go on sale for significant discounts. I can't remember how much mine was, but it was on sale. Also, I think the batteries only last for a certain number of years (whether you use them or not) but I just lost power last week and this UPS worked just fine.
novicejr is offline   Reply With Quote
The Following User Says Thank You to novicejr For This Useful Post:
supers05 (07-22-2015)
Old 07-22-2015, 05:28 PM   #14
Rewards Points: 46
2-5 years depending on use and model. I've changed my batteries twice already, but need to buy more again. (i have 3 ups boxes) The batteries are a whole lot cheaper then a new box. It's more pronounced the larger the ups. Mine are 1440VA, which last a significant time even with my computer still running. With just the modem /router it's something like 2 weeks. Lol.
Cheers!
Backup Sump pump battery question jazzyj Plumbing 4 09-09-2012 10:07 PM
APC Battery Backup - Extending Run Time with BIG Battery Bank homerb PC Repairs & Upgrades 31 05-03-2012 05:40 PM
Sump Pump Backup Battery Error? dajonx Electrical 11 09-29-2011 11:10 AM
Connecting a battery backup to an extension cord (or vice versa); safe? kev77 Electrical 2 03-19-2011 01:02 PM
