Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > PC Repairs & Upgrades
Old 01-25-2010, 09:54 AM   #1
Acer Aspire 5570z not getting any power? HELP!
My Acer Aspire 5570z is not getting any power. Someone told me to check to see if the connector is loose, I checked it and it is solid and connected to the board and not loose. Could it be the power management chip? I would need to replace the motherboard to correct this right? Someone please help with this solution?
computerguy is offline   Reply With Quote
Old 01-25-2010, 11:50 AM   #2
Do you know anyone with a known working power supply?
also. unplug it, pull the battery and try it without the battery.
Dont replace your mobo till you do some more diags.
usually it's a bad power supply or a broken solder joint on the motherboard which you may be able to get fixed.
bigcaddy is offline   Reply With Quote
Old 01-25-2010, 04:30 PM   #3
I have done some thinking this afternoon after getting the docs off the drive...I am going to purchase a new laptop as this on is very, very old and there are some other things wrong with it at this time. But thank you for getting back to me about this...not many time I get a quick response for posts.
~ Erik
How do I get power to a new ceiling fan? sestivers Electrical 12 04-25-2011 03:11 PM
Recurring Power Oddities - Regular Schedule DamienChaos Electrical 16 10-21-2009 08:45 PM
house power supply upgrade in Australia pcd1965 Electrical 3 08-22-2009 09:17 PM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 02:55 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 11:23 PM
