Mate EMT To NPS/NPT Pipe Threads? - Metal Fabrication - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Metal Fabrication
Old 08-02-2016, 09:18 PM   #1
Rewards Points: 177
Mate EMT to NPS/NPT Pipe Threads?
Hello,
Is it possible to mate EMT and NPS/NPT pipe threads?
I have an security camera mount (aluminum pipe) that the manufacturer states "will work with NPS or NPT threads", but it is really tight when attempting to mate with standard steel plumbing pipe. I can also see that the camera mount threads are starting to get chewed up a bit and have stopped before too much more damage. However, using an EMT coupling on the aluminum pipe for testing finds the fit a breeze. Regardless of the manufactures information, it looks as though the merging of plumbing and electrical pipe hardware is not working here.
So, is there any easy way to alter either set of threads to make the combination work? If not, I will just take the project to a machine shop and let them deal with it.
Peace,
Dr. Z.
Zeigh is offline   Reply With Quote
The Following User Says Thank You to Zeigh For This Useful Post:
abrowning (03-20-2017)
Old 08-02-2016, 09:59 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,612
Re: Mate EMT to NPS/NPT Pipe Threads?
Ayuh,.... It sounds like the threads on this piece are boogered up,...
Chase 'em with an appropriate die, 'n it oughta be good as new,....
Old 08-02-2016, 10:48 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 792
NPT threads are tapered and I believe NPs threads are straight- sounds like your tapered pipe threads are getting tight
Old 10-28-2016, 10:26 PM   #4
Electrical Contractor
Rewards Points: 312
Your camera mount is likely threaded for an electrical 1/2" fitting. Electrical 1/2" fittings thread into mechanical 1/2" fittings too.....they are both NPT. Tapered? Yes.
Power- is offline   Reply With Quote
Old 01-18-2017, 04:10 PM   #5
Rewards Points: 1,278
Originally Posted by Zeigh View Post
Hello,
Peace,
Dr. Z.
keep in mind that pipe sizes refer to inside diameter, and many trades use the same inside diameter, but the wall thickness would differ
KPDMinc is online now   Reply With Quote
Old 01-22-2017, 12:32 PM   #6
Bondo's Avatar
Ayuh,.... While that is in fact true,....
1/2" tapered pipe thread, is still 1/2" tapered pipe thread regardless the thickness of the pipe,...
'n in My experience, 1/2" tapered pipe thread used in electrical stuff is the same 1/2" tapered pipe thread used in plumbin',...
Old 01-23-2017, 10:01 AM   #7
But there ARE differences - 1/2" EMT outside diameter is MUCH smaller than say, PVC Coated Rigid 1/2"... just assumed there to be a slight difference between trades...
Old 01-23-2017, 05:29 PM   #8
Bondo's Avatar
Ayuh,... 1/2" Emt is so thin, ya use a connector adapter for 1/2" pipe threads,...
The tubin' itself isn't threaded,...
Best pipe to use without sag for projection screen scampy74 Home Theater 4 08-30-2016 10:27 AM
How to Estimate Water Flow Rate in Copper Pipe arskiracer Plumbing 12 04-15-2013 08:50 PM
Cleaning galv pipe threads Joe F Plumbing 6 09-30-2011 05:27 AM
Lead Drain Pipe Project Turbo98 Plumbing 33 01-30-2011 11:27 AM
Condensation in Gas Furnace Vent Pipe chanco HVAC 2 01-08-2011 04:01 PM
