Fixing Fence Idea's ? - Metal Fabrication - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Metal Fabrication
Like Tree1Likes
  • 1 Post By TheDoc46
Old 11-11-2015, 03:59 PM   #1
Rewards Points: 44
Hi,
I had a fence installed 4 yrs ago. The aluminum rails are attached from underneath via a couple of screws from the underside. You can see in one of the photo's a screw that's come out.. Unfortunately quite a few railings have come loose. (gardeners and wind i guess) While i have managed to fix one or two, via digging out a trench, underneath the fence, its very difficult to get a screw in from the underside and tightening it up. The top doesn't come off easiliy as far as i can tell.
I was wondering what other options i had in permanently fixing this fence.. Before my 20lb dog, who'll fit through a lose railing escapes chasing off some rabbit.
I was thinking of either getting some aluminum L brackets and screwing them in using a self tapping screw... Or even better, some kind of bond, that'll adhere to the painted aluminum. It doesn't need to be strong enough to swing an ape off it, just enough to hold it in place so that when the wind blows, it doesn't rattle the screws out the bottom of it.
Or I'd be happy to try my hand at welding some re-enforcing spots. Just wouldn't know what type of welder to use.
Here are some pics of the said fence.
TheDoc46 is offline   Reply With Quote
Old 11-11-2015, 04:07 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 822
Unless you get the brackets and they are powder coated black, I would just screw through at an angle from the top down to screw through the baluster and pick up the bottom rail.
Old 11-11-2015, 04:44 PM   #3
Rewards Points: 44
I can get dark brown aluminum brackets used for lanai repair, at lowes for next to nothing.
But if i can avoid that and just screw down from an angle then that may work.. Screw won't fit flush though. Could do it from the outside (lake side) so i'll never it.
Old 11-11-2015, 04:50 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 330
Ayuh,.... You'll have to prick-punch the spindle, pre-drill the hole, then use SSteel screws,....
Don't over-torque 'em, SSteel screws break quite easily,...
Bondo is online now   Reply With Quote
Old 11-11-2015, 05:53 PM   #5
Rewards Points: 144
I have done a lot of welding over the years and unless you are experienced in welding AL don't try it .You will make a mess of it.The fence should have never been installed that close to the ground to start with.Is there a insert in the bottom of the tubing the screws go into?How many need fixed?
mako1 is offline   Reply With Quote
Old 11-11-2015, 08:49 PM   #6
Rewards Points: 44
Yes each rail has two screw holes. Problem is getting to them.
Hence the question of using an alternative method. Perhaps screwing in an L bracket on each loose rail.
Or perhaps an all weather bond ? I'm not really sure the best route to go
Another option maybe is a long self tapping aluminum screw in at an angle ?
What would the pro's do?
Old 11-11-2015, 09:32 PM   #7
Rewards Points: 140
probably take it down, repair it, put it back up.
Fix'n it is offline   Reply With Quote
The Following 2 Users Say Thank You to Fix'n it For This Useful Post:
Bondo (11-12-2015), Msradell (11-11-2015)
Old 11-12-2015, 08:15 AM   #8
Rewards Points: 3,707
I can't think of anything better so here is all I got.
A close quarter (AKA right angle) drill may create the need for less digging. Use SS screws if you can find the right ones.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
Old 11-12-2015, 08:30 AM   #9
Rewards Points: 368
The pros built it, it failed, so I wouldn't follow their foot steps. Your L bracket idea would be my first DIY'er choice after welding.
Old 11-12-2015, 01:44 PM   #10
Bondo's Avatar
Rewards Points: 330
Ayuh,.... Weldin' is Not an option,....
Aluminum weldin' is done with shielding gases, usually indoors,....
The aluminum has to be perfectly Clean, which means grindin' off the finish,...
Diggin' a trench, 'n runnin' new ssteel screws in from below with a impact driver is probably still the Best option,...
My makita with a short bit would fit in a single scoop of a spade shovel,...
Put a dab of glue on each screw to hold it's place,...
Old 11-12-2015, 08:40 PM   #11
Rewards Points: 140
sure it is, no problem. MIG it on a calm day.
Old 01-05-2017, 02:47 PM   #12
Rewards Points: 44
Re: Fixing Fence Idea's ?
OP here...Just updating this... as it was over a yr ago... yes the way the problem was fixed is exactly as you mentioned. Dug a trench / hole at each loose baluster, and ran some new steel screws in from underneath, using a small compact Makita impact. Fixed it that way. And as long as you don't mind getting your tools a little dirty, its the best quickest fix !
Bondo likes this.
The Following User Says Thank You to TheDoc46 For This Useful Post:
Bondo (01-05-2017)
Leaky - Double Wall Polycarbonate Pergola Roof Need Ideas for Fixing MexTex78 Roofing/Siding 2 12-28-2011 11:41 PM
Corrugated steel fence? ITSANSS Landscaping & Lawn Care 2 04-13-2011 08:04 AM
Frustrated/Confused in FL Fence jjrbus Building & Construction 5 09-02-2009 10:52 AM
Questions About Fixing an Old Fence Robdude Carpentry 2 05-16-2009 06:27 PM
design ideas for fixing crappy addition? wombosi Building & Construction 2 04-27-2009 05:39 PM
