Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Home Theater
Old 03-25-2010, 03:48 PM   #1
Question
wiring a ceiling suspended projector
i am ready to set the wiring for my ceiling suspended projector:
http://www.bhphotovideo.com/c/produc...specifications
which has the following I/O connectors:
Computer
VGA: D-sub 15-pin x1 Video
HDMI IN: 19-pin x2
Component: RCA x3
S-Video: Mini DIN 4-pin x1
Composite Video: (RCA) x1
i will want to output DVD, cable, and computer on it.
what kind of cables and connectors will i need to run to the receptacle box i am setting in the ceiling close to it ?
thanks
Old 03-25-2010, 05:20 PM   #2
the Musigician
DangerMouse's Avatar
Most likely, you'll need....
HDMI IN: 19-pin x2
Component: RCA x3
For what you want to do, you'll probably need to use them all. You using HDTV?
Radio Shack or similar should have all/most of these.
Take your list. *Happy Hunting!*
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
The Following User Says Thank You to DangerMouse For This Useful Post:
amakarevic (03-25-2010)
Old 03-25-2010, 05:58 PM   #3
Question
can i buy RCA cable in a spool and just crimp my own connectors ?
Old 03-25-2010, 06:05 PM   #4
the Musigician
Sure! I like the "open the rca jack and solder, screw cap back on and go" types myself. (avoid plastic) But there are other ways too.
You can make the cables pretty long without loss.
DM
Old 03-25-2010, 06:16 PM   #5
Question
is soldering the only option (never soldered wire nor do i have a gun) or can it also be crimped ?
Old 03-25-2010, 06:36 PM   #6
the Musigician
They make them "screw on the wires" too. I just like a solder connection.
DM
Old 03-26-2010, 08:42 AM   #7
Before doing a lot of wiring, I ask what are the cable, DVD, and computer outputs? Do all have HDMI? How are you switching from one source to another?
For most of us, I believe HDMI is the current standard, with switching through an audio reciever or matrix or similar device. If you have HDMI from your sources, I see no reason to install S-video, composite, or even component. Perhaps there is some value in running some extra wires in case you ever need some analog signal such as VGA, component, RGBHV, whatever. You may also want to run cat-5, just in case. Wire is cheap. Until you actually need it, however, there is no need to install any particular connectors. Stick with HDMI as your current interface of choice.
If you don't have HDMI from all your sources, you should consider an up-converting reciever. They are becoming pretty economical at this point.
oberkc is offline   Reply With Quote
Old 03-26-2010, 09:25 AM   #8
the Musigician
Ya gotta consider all the inputs/outputs you'll be using.
DVD separate unit = (normally) rca jacks - red/white/yellow
Computer (normally) s-video + audio cable in some cases.
HDTV, different cable, (not familiar with these)
Cable = co-axial cable
On my setup, we watch avi/mpg movies/cartoons, and dvds from computer to (not HI DEF) TV.
DM
Where to place projector wiring dstylez Home Theater 12 11-13-2009 10:52 AM
Help wiring ceiling light wylde8 Electrical 1 09-24-2009 07:29 AM
Wiring a projector to a switch? (will this work) c3lica Electrical 10 04-07-2009 10:04 PM
New Ceiling fixture Wiring Question rsteps Electrical 4 07-12-2007 08:51 AM
Ok to run wiring between strapping in the ceiling? peeks Electrical 5 08-29-2005 01:12 AM
