Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Home Theater
Old 08-28-2011, 02:07 PM   #1
Question
What's the best IR repeater?
Hi All,
Wondering if anyone has experience with any of the IR repeaters on the market? We are getting a nice flat screen TV for the bedroom, and all equipment will be down the hall in the closet. Really do not want to have to have my cable box, etc hanging around on a little stand/table/shelf, etc.
Thanks,
Nicole
New_2_DIY is offline   Reply With Quote
Old 08-28-2011, 02:46 PM   #2
Experienced
Jackofall1's Avatar
Well Nicole, I had purchased one at Bestbuy a couple of years ago, transmitter and receiver which used the remote from DTV, It worked fine and it was some 45 ft apart and on different floors.
If I remember correctly it was about $100, the only problem I had to figure out was, the wireless modem for my network would interfere with the signal so I would have to unplug the modem when watch TV upstairs, this effected anyone of the (4) channels available on the TX or TR.
Mark
Old 08-29-2011, 09:48 AM   #3
We have one made by Cables to Go. Got it from Amazon for about $40. We use it in the living room to control the DirecTV box located in the kitchen.
We also have one that's made by URC. We use it upstairs to control the same DirecTV box in the kitchen. The remote sends an RF signal and the blaster converts the signal back to IR. No wire between the two is needed, but the response has a small delay.
leungw is offline   Reply With Quote
Old 08-29-2011, 02:11 PM   #4
Thanks, I saw the Cables to Go product, but I have ATT U-Verse, so that one will not work. After a bit of searching, I think I'm going with the Hot Link XL, seems to be a good one (at least from the reviews on amazon). Called the company to ask a few questions and got very good customer service, so that's a good sign.
Thanks for the info
-Nicole
Old 08-29-2011, 02:15 PM   #5
Mark
Ah, yes we also have a wireless modem and a 2.4 GHz phone so not sure another wireless product would be compatible. I found a hardwired product at around the same price, already have Cat5 run from the bedroom to the closet so I think I'm set, but thank you
Old 08-29-2011, 02:52 PM   #6
DIY Hack
Mr Chips's Avatar
You mentioned "cable box" so this may not apply to you, but it's worth mentioning just in case that most of DirecTv boxes have RF capability built in.
If you do have DTV, check your remote. if the model # of your remote ends in an R ( like RC64R) thats RF & IR compatible. then go to the remote set-up menu for your box and if it allows you to chose RF you just follow the directions and you'll be all set. I have all my boxes set up for RF and in different rooms than the TVs, makes for a much cleaner look
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 08-29-2011, 02:57 PM   #7
Yes, I wish DirecTV would put RF in all their boxes. We subscribe for its Chinese channels which come only in SD. So our box is the plain old SD box without RF.
Tags
remote control, repeater
RadioRA 2 Programming Question? altow90 Electrical 1 07-06-2010 05:41 PM
