What Would Be The Required Wood Screw Depth For Mounting? - Home Theater - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Home Theater
Old 10-24-2008, 07:56 AM   #1
Designer
Rewards Points: 44
What would be the required wood screw depth for mounting?
Hi there,
can anyone tell me or point me to somewhere that i can find out what the holding strength of wood screws are?
I'd like to know how deep my wood screws should be when mounting a shelf to a wall (through 1/8" steel and drywall, with 3 screws vertically into 1 stud), that will hold a receiver thats almost 40 lbs.
any help would be greatly appreciated.
cdpage is offline   Reply With Quote
Old 10-24-2008, 08:26 AM   #2
RippySkippy's Avatar
When you're working with wood, that alone has to many variables to say you'll get X amount of holding from a given screw. Some studs are more dense which means they will hold better than others.
Don't use a drywall screw to mount something like you're talking about. Go to one of the home centers, and look for structural screws. I like the GRK brand that have a larger head, and thicker shank than most. A good smaller hardware store cares the GRK brand and if you get them...don't forget to pick up a bit as well. The torx heads rock.
For what you're doing with the shelf...assuming the brackets are heavy enough, I would used 2" screws. It may be over kill, but then again it won't fall down.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 10-24-2008, 09:00 AM   #3
Designer
Rewards Points: 44
thanks for the fast reply!
I'm can't sure of the thickness of peoples drywall... it could be 3/8" or 5/8".
assuming the worst lets say its (5/8") and adding the mounts plate, which is about actually about 3/16" a total of about 13/16". that would give the screw only 1 3/16" of dig into the wood. times 3 screws of course.
would that still be considered safe?
Old 10-24-2008, 09:38 AM   #4
well over half of a 2" screw...yes it would be safe.
LMASD
Old 10-24-2008, 12:22 PM   #5
Designer
Rewards Points: 44
Great!
thanks so much.
Tags
wall
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Ext Paint for Interior Application? PaoloM Painting 24 04-21-2009 04:30 AM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 11:19 AM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 09:14 AM
