What Kind Of Projector? - Home Theater - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Home Theater
Old 11-25-2009, 02:02 PM   #1
What kind of projector?
What kind of projector does everyone have? Is one with 800x600 native resolution good enough or not.
Kurt1968 is offline   Reply With Quote
Old 11-25-2009, 02:10 PM   #2
Good enough for what?
jerryh3 is offline   Reply With Quote
Old 11-25-2009, 05:06 PM   #3
For watching movies and playing video games.
Old 11-25-2009, 11:10 PM   #4
Too Short? Cut it Again!
These laser pico projectors have been threatening to hit the market for awhile now. Could be cool and they should be out soon. I seem to remember a hinted price point of around $250-300.
http://www.microvision.com/index.html
Old 11-26-2009, 06:35 AM   #5
Are you buying this new? This is taken from one of the better projector sites:
Will an SVGA Projector Do as Well as an XGA?
What about those very inexpensive SVGA projectors? Well, if you want to enjoy HDTV, don't even consider one. Because of its much lower-resolution 800 x 600 internal panel (as compared to an XGA projector's 1024 x 768) the final picture will contain even less resolution than a standard NTSC TV signal! This is because, when an incoming 720p or 1080i HDTV wide-screen image is mapped onto the projector's panel, it needs to first be "shrunken" by 37.5% (if 720p) or 41.7% (if 1080i), so that the original 1280-pixel-wide HDTV image (if 720p) or 1920-pixel-wide image (if 1080i) will fit onto the 800-pixel-wide SVGA panel. The proportional percentage shrinkage in the vertical dimension results, in either case, in an image that no longer contains 720 or 1080 lines of resolution, but rather 450, which is less than standard TV's 480 lines!
Old 11-26-2009, 09:25 AM   #6
Yes it will probably be a new one. I just dont want to spend 1000s of dollars on one. Maybe 400.00 to 500.00.
Old 11-26-2009, 09:39 AM   #7
If you can stretch that to about $650 you can pick up one of these. That will get you into the lower end home theater projectors.
http://www.amazon.com/Optoma-HD65-72...9249750&sr=8-1
Old 11-27-2009, 07:24 PM   #8
Rewards Points: 1,514
The Microvision laser picop projectors as described have a resolution of 800x480, enough for standard definition shows and regular DVD.
The laser beam scans back and forth, and slowly down the screen like a CRT electron beam. Unlike the phosphors on a CRT tube screen, each pixel position does not stay illuminaated for a 60'th of a second or so after hte beam passes on, so some folks may see an overall shimmering or flickering of the picture.
New kind of weed in lawn? VelvetFoot Landscaping & Lawn Care 9 11-14-2009 10:11 PM
Where to place projector wiring dstylez Home Theater 12 11-13-2009 09:52 AM
Wiring a projector to a switch? (will this work) c3lica Electrical 10 04-07-2009 09:04 PM
Painting wall for Projector SnowUtopia Painting 2 08-12-2008 09:20 AM
Projector Receiver cable TV box bigboyjoel Home Theater 4 12-19-2007 02:23 PM
