Are We On The Air ? - Home Theater - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Home Theater
Old 01-13-2009, 08:02 AM   #1
Rewards Points: 150
Are we on the air ?
Yesterday I ran over to hook up one of those TV converters for my wife's aunt ! 6 year old GE. using a Philco Converter box.
Simple welllll , Not so ? It was easy to just plug in the power to the converter, next insert the antenna cable coming in, into the cable in conection. then using the coax cable in the box I inserted this from the converter box out to the TV " only one conection " I can't blow this ah?
Well nothing happend I only received static and snow over the pictured on each chanel. double checked my wireing made sure the middle wire was inserted into the center hole.
Tried to switch to channel 3 nothing doing here. tried channel 4 nope. geeezzz!
one hour later I quit"
Maybe their not broadcasting in digital yet ?
and this is why I'm not getting any results.
Could not bring up Menu per instructions in booklet either.
Is it posible these converters will not work untill Feb. ?
or should they work right now ?
I will take any offers of assistance here
Deck hand
deck hand is offline   Reply With Quote
Old 01-13-2009, 11:32 AM   #2
Licensed Electrician
Magnettica's Avatar
Rewards Points: 150
Send a message via Yahoo to Magnettica
gxmh bghgf ddhdh
Magnettica is offline   Reply With Quote
Old 01-13-2009, 11:43 AM   #3
Rewards Points: 150
Originally Posted by Magnettica View Post
gxmh bghgf ddhdh
I don't know what you wrote ?
deck hand
Old 01-13-2009, 11:43 AM   #4
What kind of antenna was it hooked up to?
jerryh3 is offline   Reply With Quote
Old 01-13-2009, 12:22 PM   #5
Rewards Points: 150
Out side roof the tV works great on reg old ant. hook up
deck hand
Old 01-13-2009, 12:49 PM   #6
the Musigician
DangerMouse's Avatar
look in the _TV's_ menu for 'search channels' maybe that will find them? try cable AND antenna.
DM
Old 01-13-2009, 02:06 PM   #7
Rewards Points: 150
DM
The question is should the tv picture work after I hook up the new box now like it worked prior to the new converter or only after feb date.?
Deck hand
Old 01-13-2009, 03:21 PM   #8
the Musigician
supposedly, they're already working on some/most/all channels? but you may need to explore your local channel's websites to see if and who is in your area for sure, to test your equipment. they are also broadcasting tests to check. try to catch one of those if nothing else works.
maybe no-one in your area is doing the digital boogie yet.
DM
Old 01-13-2009, 03:39 PM   #9
deck hand
Unless the box has an analog pass-through, it may only be able to receive ATSC(digital) signals. Depending on the area, the local stations may not be broadcasting in digital yet. It does seem weird though, there should be at least a few digital signals. Does the box have composite output? Does the TV have composite input? Can you post the model number of the box.
Old 01-14-2009, 02:14 PM   #10
Rewards Points: 6,652
If you are able to show the menu of the box on the TV set, then it is hooked up correctly to the TV. From there, you should be able to auto-scan for stations. If the coax is old, you may wish to have it replaced from the antenna to the box with newer RG-6. As for the hook up, Antenna In on the box, TV-out to the set, if wired with a 3-6' coax jumper. Easy way, is to follow the directions that came with the ATSC tuner and you should have no problems.
Old 01-14-2009, 05:40 PM   #11
Rewards Points: 150
Gregzoll
I called the 800 number today, I guess there is something not right about the TV settings ?
I have to find the TV model and /or find the book and get it to tune in channel ( 3 ) she has the TV screwed up, If I can't find the book I can call for assistance from GE with the TV Model and they can walk me through it. " Wish Me luck "
deck hand
Old 01-14-2009, 07:00 PM   #12
On the remote for the TV press 3. From there, use the remote for the ATSC tuner, and you should also be able to set that remote up since it is a universal to control the TV set. If not able to call GE, you should be able to get the model# and look on GE's website.
Old 01-17-2009, 09:19 AM   #13
Rewards Points: 150
tunner problem ch. 3
I know about the remote for channel 3 it's that when ever I had pushed the 3 button and / or arrowed up to 3 the tv automictly jumped pass 3
this is why I need the book ? and or look on the web site for GE.
to re-progrham the tunner ! to except 3 and my aux.
Deck hand
it's 0 degrees out side in Michigan
Deck hand has flew to Cancun for a week !
Old 01-17-2009, 10:37 AM   #14
Deck hand
You may have to reprogram or add channel 3 to the TV. It's usually just an option under the tv's options menu. Make sure the converter box is on when you do it.
Old 01-17-2009, 11:05 AM   #15
If that is the case, it is not a TV programming issue most likely. As for the book, you do not need it. Just press the Menu button on the front of the TV set, and go to Manual Programming.
