Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Home Theater
Old 08-09-2012, 10:32 PM   #1
Wall mounting to cinder blocks behind drywall
Hey everyone,
Looking for a bit of advice I was planning on wall mounting my plasma tv 42". I just learned that in my town home the wall I would like to mount on is not studded with 2x4 it looks like it is just small studs aprx 1" by 2" concrete screwed into cinder blocks to mount the drywall to and they are not 16" apart there is only one stud down the center of the room (where I would like to mount the tv) and the next studs are about 30" from there ( much too far apart for a wall mount bracket). My question is how can I still wall mount this tv in the center of the room? I know I can drive a couple tapcons in the middle "stud" but that won't be enough support I would think. Without destroying too much wall how can I get some more support? Mainly on the outer corners of the mount.
Andrew87 is offline   Reply With Quote
Old 08-09-2012, 11:30 PM   #2
That's a tough one. Cinder block is delicate to drill into. I don't have the answer but try asking here:
www.remotecentral.com under the Custom Installer's Lounge
Custom Installers hang out here and might a better idea.
There also www.avsforum.com. There's the
Dedicated Home Theater Design and Construction
General Home Theater & Media/Game Rooms
both would be good forums to ask in.
paw1 is offline   Reply With Quote
Existing cinder block wall is still true. orphanedious Building & Construction 5 06-30-2011 03:29 PM
In wall gutter downspout causing mold on drywall. chrispy35 General Discussion 12 05-06-2011 11:35 PM
drywall over cement 'blocks' ? jthn Drywall & Plaster 3 01-03-2011 09:29 PM
Mounting Corner Wall Mount Sink petedickson82 Plumbing 2 02-17-2010 10:28 PM
Half-height Cinder Block wall Electrical theatretch85 Electrical 11 04-09-2009 12:49 AM
