-   Home Theater (http://www.diychatroom.com/f12/)
-   -   video in sockets on most new flatscreen TVs (http://www.diychatroom.com/f12/video-sockets-most-new-flatscreen-tvs-143556/)
amakarevic 05-12-2012 04:19 PM
i was wondering how many and what kind of video IN sockets there are on most modern flatscreen TVs. i need to know that because i am doing behind-the-wall wiring. i guess most have an F connector and HDMI but do they have a separate RCA in as well for component cables?
i was thinking of running 2 RG-6 cables behind the wall, one terminated in F and the other RCA for the cable box and DVD/GoogleTV respectively. as far as HDMI, since i can't terminate it, that was just gonna go exposed.
thanks
Jay 78 05-12-2012 05:46 PM
It depends.
Cheaper brands won't have as many inputs. Cheaper TV's by the big brands often have less inputs. That's part of what makes then cheaper.
Most modern TV's I've seen still have a composite input - although they're pretty much useless nowadays. All should have both component and of course HDMI, and many have VGA. Here and there you'll still find S-video.
Running a set of component cables wouldn't hurt, since most cable boxes and DVD/Blu-Ray players have them, and it's the only other non-HDMI way to transmit a HD signal. Anything that can be connected via HDMI should be, since it yields the best audio and video quality possible.
gregzoll 05-12-2012 06:19 PM
You can get 'L' connectors for HDMI, RCA, Coax, SPDIF, etc., now days. Depending on how much room from the back of the tv with the bracket you are using, depends on how much "flex" room you have.
All you really need, is 3 runs of RG-6 for the Video portion of Component, add two more if you are going to be using the tv for sound, but most people are going with sound bars for the sound, since tv speakers are lacking. Regardless of how far of the run for HDMI, go with Cat-6 or Cat-5e for HDMI over ethernet. That is all you really need to the tv, not two thousand different cables, since most switching is done through a avrs, or such.
amakarevic 05-12-2012 07:14 PM
my NEC projector, on the other hand, has only a single component video RCA jack...
gregzoll 05-12-2012 07:32 PM
So, just run one run of RG-6 if you wish for that.
wkearney99 05-13-2012 07:30 PM
No, if it's just one connector then it's a COMPOSITE video signal. Component requires three; red, green and blue, one connector each.
It's pretty pointless to pull RF coax to a modern TV unless you plan on using an over-the-air antenna. Better to use HDMI or component. Bear in mind, component along with audio requires a lot more wire than HDMI, this also means larger conduit, and labor to pull it.
