Tv Wall Mount Height Formula - Home Theater - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Home Theater
Old 08-29-2013, 02:25 PM   #1
bryanp22's Avatar
Rewards Points: 294
Tv wall mount height formula
Anyone know of a formula to calculate how high I should Mount a 50" TV? Does viewing distance matter?
bryanp22 is offline   Reply With Quote
Old 08-29-2013, 02:30 PM   #2
http://www.crutchfield.com/Learn/lea...placement.html
http://simplicity.sanus.com/index.php/us/en/mountwizard
Yes, viewing distance matters. It's probably more important than height.
Ever sat in the front row of a movie theater? You get a crick in your neck from staring almost straight up.
AJPLeBlanc is offline   Reply With Quote
Old 08-29-2013, 02:37 PM   #3
bryanp22's Avatar
Rewards Points: 294
This doesn't really go into mounting height though. I'm about 10 feet from tv. Only thing I've found so far is middle of TV at eye level on couch. Is that a good idea to follow?
Old 08-29-2013, 02:41 PM   #4
Ideally, yet, it reduces eye fatigue. I think really it comes down to whats comfortable. You might be able to test it by sticking something to the wall and sitting in different spots to see if you have to crane your neck to see it, etc.
Old 08-29-2013, 09:59 PM   #5
Rewards Points: 236
that is an excellent starting point. a little lower or higher is not bad, it is just personal preference .
now, if you were talking a LARGE screen = 90"+ then you want to divide the screen horizontally by 3rds. then you set the screen height to look straight at the bottom (of 3) line.
Fix'n it is offline   Reply With Quote
What should be the height of wall? so roof pitch is 10 feet... vikasintl Roofing/Siding 2 07-04-2012 10:32 PM
Want to mount a sconce on the wall where there is a stud pdp76 Electrical 24 04-01-2011 05:07 PM
Can I mount a window A/C into the wall, exhausting to the attic? Greg2230 HVAC 2 06-01-2010 08:56 PM
Mounting Corner Wall Mount Sink petedickson82 Plumbing 2 02-17-2010 09:28 PM
wall mount toilet jjrbus Plumbing 8 11-12-2009 01:07 PM
