Tv Repair - Home Theater - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Home Theater
Old 09-26-2010, 06:44 PM   #1
Unhappy
tv repair
i have a RCA bigbox 52'' tv about 5/6 yrs old works perfert until lastnite the sound just stop working the only sound is the DVD which is from surround sound, i was wondering if there might be a fuse blown, can anyone help me.
lynnster is offline   Reply With Quote
Old 10-04-2010, 08:16 AM   #2
Rewards Points: 1,440
Does the Video 2 input still work (try it with a different DVD player or VCR using different red/white cables) or is there no sound from the TV speakers no matter what the source is?
The Following User Says Thank You to AllanJ For This Useful Post:
lynnster (10-04-2010)
Old 12-23-2010, 07:16 AM   #3
bofusmosby's Avatar
If I understand correctly, the only sound is with your DVD player, and that sound is through your surround-sound system. OK, being familiar with the TV you have, first, check on the back of the set. On some models, there is an internal/external switch for the speakers. If this is not your problem, then go into the TV menu. First, make sure that your speakers are not turned off. Then go into "advanced settings and make sure that the sound is switched to "internal amplifier". If this also is not your problem, then you need to take the set to a service shop. The sound ckt. on your set is on the "small signal board", and I do not recommend ANYONE to try and repair this board unless you are a good TV repair tech. I doubt that this is your problem though. The 2 things I described will probably take care of your problem.
bofusmosby is offline   Reply With Quote
$1440+ labor only repair on 3 yr. old Goodman unit!?! JMK HVAC 23 05-06-2012 11:45 AM
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 09:49 AM
Repair Compounds saggdevil Painting 3 04-25-2010 04:02 PM
What do you guys think of this roof repair job? darsunt Roofing/Siding 7 08-21-2009 09:43 PM
AC repair am I being scammed 911 hurley0351 HVAC 55 05-18-2009 09:14 AM
