Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Home Theater
Old 01-28-2010, 10:17 AM   #1
Trying to hook my PS3 up to an older HD tv
what is the best connection i can get with this tv. Mits wt 46809. There is no HDMI connection on this tv and I am trying to get the best connection possible with my PS3. thanks
shizark420 is offline   Reply With Quote
Old 01-28-2010, 10:35 AM   #2
E-lec-tri-city
Send a message via ICQ to brons2 Send a message via AIM to brons2 Send a message via MSN to brons2 Send a message via Yahoo to brons2
What kind of inputs does the Mitsubishi have? DVI? Component video?
brons2 is offline   Reply With Quote
Old 01-28-2010, 10:48 AM   #3
Coconut Pete's paella!
CoconutPete's Avatar
If the TV has no HDMI and it's truly an HDTV then it has Component inputs on the back. That is your best bet and only way to get an HD signal from the PS3 to the TV.
CoconutPete is offline   Reply With Quote
Old 01-28-2010, 10:56 AM   #4
Mitsubishi WT-46809 specifications
  • General
  • Product type Rear projection TV
  • Diagonal Size 46.0 in - Widescreen
  • Enclosure Color Black
  • Display
  • Technology Projection
  • Projection Display Technology CRT
  • Display Format 1080i
  • Image Aspect Ratio 16:9
  • Image Contrast Ratio 50:1
  • Widescreen Modes Normal , Stretch , Zoom , Conventional 4:3 , Expand
  • Color Temperature Control Yes (Warm/Medium/Cool)
  • Horizontal Resolution 1200 lines
  • Progressive Scan Progressive scanning (line doubling)
  • Viewing Angle 110 degrees
  • Pixel Pitch 0.72 mm
  • Display Menu Language English , Spanish
  • Favorites List Qty 9
  • Preset Channel Qty / List 6
  • Comb Filter 3D-Y/C digital
  • V-Chip Control Yes
  • TV Tuner
  • Analog TV Tuner NTSC
  • Multi-channel Preview Split screen , Picture-out-of-picture (POP) , Picture-in-picture (PIP)
  • Stereo Reception System MTS
  • Channel Coverage UHF:14-69 , VHF:2-13 , Cable:1-125
  • Secondary Audio Program (SAP) Yes
  • Video Features
  • Video Interface Component , Composite , S-Video
  • HDTV Ready Yes
  • Freeze Memo Yes
  • Closed Caption Capability Yes
  • Audio System
  • Speaker(s) 2.0 x Right/left channel speaker - Built-in - 10.0 Watt
  • Sound Output Mode Stereo
  • Digital Sound Processor (DSP) Yes
  • Audio Controls Sound mode , Bass , Treble , Balance
  • Output Power / Total 20.0 Watt
  • Additional Features Volume limiter
  • Driver Details Right/left channel speaker : 1.0 x Full-range driver - 5.0 in
  • Connections
  • Connector Type 3.0 x Audio line-in ( RCA phono x 3 ) - Rear , 1.0 x Audio output ( RCA phono ) - Rear , 1.0 x Remote control ( Mini-phone 3.5 mm ) - Rear , 3.0 x Composite video/audio input ( Mini-phone 3.5 mm ) - Rear , 1.0 x RF output ( RCA phono x 2 ) - Front , 3.0 x Monitor output ( F connector ) - Rear , 2.0 x S-Video input ( 4 pin mini-DIN ) - Rear , 1.0 x Composite video/audio input ( F connector ) - Rear , 1.0 x Component video input ( RCA phono x 5 ) - Rear , 2.0 x Antenna ( RCA phono x 3 ) - Front , 1.0 x Fixed/variable audio output ( 4 pin mini-DIN ) - Rear , 2.0 x System components control bus ( RCA phono x 2 ) - Rear , 1.0 x S-Video input ( RCA phono ) - Rear , 1.0 x HD component video / RGB input ( RCA phono x 3 ) - Rear
  • Remote Control
  • Remote Control Universal remote control - Infrared
  • Supported Devices VCR , AV receiver , DVD player , Satellite TV system , Cable box
  • Features Multi-brand compatibility , Back-lit buttons
  • Power
  • Power Device Power supply - Internal
  • Power Consumption Operational 280.0 Watt
  • Miscellaneous
  • Included Accessories IR adapter
  • Manufacturer Warranty
  • Service & Support 1 year warranty
  • Service & Support Details Limited warranty - Parts and labor - Screen - 30 days , Limited warranty - 1 year
Old 01-28-2010, 11:24 AM   #5
E-lec-tri-city
Yep you'll need component video. Sony's official kit is only $20, pretty surprising. Has analog audio options only though, but that may be what you're looking for:
http://www.sonystyle.com/webapp/wcs/...52921665061579
If you want to use optical audio to a receiver that decodes the Dolby Digital/DTS/TrueHD/etc formats for BluRay watching, get a kit with a TOSlink optical connector instead. Here's a $40 Monster kit for example:
http://www.amazon.com/Playstation-3-.../dp/B000JLD1I8
Old 01-28-2010, 11:27 AM   #6
E-lec-tri-city
In his case, that is true, but there are also 1080i HDTV's out there that have DVI connections. In that case you can buy a HDMI to DVI cable. (however, this will not help the OP of this thread)
Old 01-28-2010, 11:32 AM   #7
Thanks a ton!
Old 02-03-2010, 10:51 AM   #8
Enormous Member
skipjack's Avatar
A little FYI: CRT-based projection TV's are more prone to "burn in" than other technologies. I'm sure it's mentioned somewhere in your owner's manual but, if an image sits still on a screen for a prolonged period of time (ie: a health bar in a video game for a marathon gaming session) there is a risk of uneven wear of the phosphorus coating on the CRTs causing ghost images to remain permanently. The reason this is more of an issue on projection based TV's than standard tube TV's is that projection CRTs have to operate much brighter than standard tube-based TV's.
I'd recommend to try and keep your contrast levels below 50% to reduce the risk of uneven wear. (Actually, I'd recommend that for anyone who owns a CRT based projection TV to prolong picture life).
Have fun.
skipjack is offline   Reply With Quote
Old 02-03-2010, 11:41 AM   #9
thanks for the info!
Andersen Door Hook Latch Problem magic1whiz General Discussion 1 12-09-2009 07:03 AM
Outlet With Swith and Older (White, Black, Red) Wire CaptChaos Electrical 18 09-15-2009 12:17 AM
3 ph compressor hook up psgstl Electrical 16 06-12-2009 09:37 AM
Question about replacing load center in older house speedster1 Electrical 5 05-14-2009 08:55 AM
Water softener hook up piping? coyote556 Plumbing 1 09-12-2007 08:55 PM
