-   Home Theater (http://www.diychatroom.com/f12/)
-   -   Trying to hook my PS3 up to an older HD tv (http://www.diychatroom.com/f12/trying-hook-my-ps3-up-older-hd-tv-62993/)
shizark420 01-28-2010 09:17 AM
what is the best connection i can get with this tv. Mits wt 46809. There is no HDMI connection on this tv and I am trying to get the best connection possible with my PS3. thanks
brons2 01-28-2010 09:35 AM
1 Attachment(s)
What kind of inputs does the Mitsubishi have? DVI? Component video?
CoconutPete 01-28-2010 09:48 AM
If the TV has no HDMI and it's truly an HDTV then it has Component inputs on the back. That is your best bet and only way to get an HD signal from the PS3 to the TV.
shizark420 01-28-2010 09:56 AM
Mitsubishi WT-46809 specifications
  • General
  • Product type Rear projection TV
  • Diagonal Size 46.0 in - Widescreen
  • Enclosure Color Black
  • Display
  • Technology Projection
  • Projection Display Technology CRT
  • Display Format 1080i
  • Image Aspect Ratio 16:9
  • Image Contrast Ratio 50:1
  • Widescreen Modes Normal , Stretch , Zoom , Conventional 4:3 , Expand
  • Color Temperature Control Yes (Warm/Medium/Cool)
  • Horizontal Resolution 1200 lines
  • Progressive Scan Progressive scanning (line doubling)
  • Viewing Angle 110 degrees
  • Pixel Pitch 0.72 mm
  • Display Menu Language English , Spanish
  • Favorites List Qty 9
  • Preset Channel Qty / List 6
  • Comb Filter 3D-Y/C digital
  • V-Chip Control Yes
  • TV Tuner
  • Analog TV Tuner NTSC
  • Multi-channel Preview Split screen , Picture-out-of-picture (POP) , Picture-in-picture (PIP)
  • Stereo Reception System MTS
  • Channel Coverage UHF:14-69 , VHF:2-13 , Cable:1-125
  • Secondary Audio Program (SAP) Yes
  • Video Features
  • Video Interface Component , Composite , S-Video
  • HDTV Ready Yes
  • Freeze Memo Yes
  • Closed Caption Capability Yes
  • Audio System
  • Speaker(s) 2.0 x Right/left channel speaker - Built-in - 10.0 Watt
  • Sound Output Mode Stereo
  • Digital Sound Processor (DSP) Yes
  • Audio Controls Sound mode , Bass , Treble , Balance
  • Output Power / Total 20.0 Watt
  • Additional Features Volume limiter
  • Driver Details Right/left channel speaker : 1.0 x Full-range driver - 5.0 in
  • Connections
  • Connector Type 3.0 x Audio line-in ( RCA phono x 3 ) - Rear , 1.0 x Audio output ( RCA phono ) - Rear , 1.0 x Remote control ( Mini-phone 3.5 mm ) - Rear , 3.0 x Composite video/audio input ( Mini-phone 3.5 mm ) - Rear , 1.0 x RF output ( RCA phono x 2 ) - Front , 3.0 x Monitor output ( F connector ) - Rear , 2.0 x S-Video input ( 4 pin mini-DIN ) - Rear , 1.0 x Composite video/audio input ( F connector ) - Rear , 1.0 x Component video input ( RCA phono x 5 ) - Rear , 2.0 x Antenna ( RCA phono x 3 ) - Front , 1.0 x Fixed/variable audio output ( 4 pin mini-DIN ) - Rear , 2.0 x System components control bus ( RCA phono x 2 ) - Rear , 1.0 x S-Video input ( RCA phono ) - Rear , 1.0 x HD component video / RGB input ( RCA phono x 3 ) - Rear
  • Remote Control
  • Remote Control Universal remote control - Infrared
  • Supported Devices VCR , AV receiver , DVD player , Satellite TV system , Cable box
  • Features Multi-brand compatibility , Back-lit buttons
  • Power
  • Power Device Power supply - Internal
  • Power Consumption Operational 280.0 Watt
  • Miscellaneous
  • Included Accessories IR adapter
  • Manufacturer Warranty
  • Service & Support 1 year warranty
  • Service & Support Details Limited warranty - Parts and labor - Screen - 30 days , Limited warranty - 1 year
brons2 01-28-2010 10:24 AM
1 Attachment(s)
Yep you'll need component video. Sony's official kit is only $20, pretty surprising. Has analog audio options only though, but that may be what you're looking for:
http://www.sonystyle.com/webapp/wcs/...52921665061579
If you want to use optical audio to a receiver that decodes the Dolby Digital/DTS/TrueHD/etc formats for BluRay watching, get a kit with a TOSlink optical connector instead. Here's a $40 Monster kit for example:
http://www.amazon.com/Playstation-3-.../dp/B000JLD1I8
brons2 01-28-2010 10:27 AM
1 Attachment(s)
In his case, that is true, but there are also 1080i HDTV's out there that have DVI connections. In that case you can buy a HDMI to DVI cable. (however, this will not help the OP of this thread)
shizark420 01-28-2010 10:32 AM
Thanks a ton!
skipjack 02-03-2010 09:51 AM
A little FYI: CRT-based projection TV's are more prone to "burn in" than other technologies. I'm sure it's mentioned somewhere in your owner's manual but, if an image sits still on a screen for a prolonged period of time (ie: a health bar in a video game for a marathon gaming session) there is a risk of uneven wear of the phosphorus coating on the CRTs causing ghost images to remain permanently. The reason this is more of an issue on projection based TV's than standard tube TV's is that projection CRTs have to operate much brighter than standard tube-based TV's.
I'd recommend to try and keep your contrast levels below 50% to reduce the risk of uneven wear. (Actually, I'd recommend that for anyone who owns a CRT based projection TV to prolong picture life).
Have fun.
shizark420 02-03-2010 10:41 AM
thanks for the info!
