Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Home Theater
Old 01-10-2010, 10:30 AM   #1
Trying to go TVless-best converter box
Well, dishless at least. I know we missed out on the coupon stuff. Older TVs need the digital converter, correct? Our "big" TV (32 in) is a minimum of 12-15 yo, but still gets great picture.
Which are the good converter boxes? Is quality an issue with some?
Thanks!
Bill7 is offline   Reply With Quote
Old 01-10-2010, 07:57 PM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
Consumerreports.com and also you can check out AVSforums.com. Consumer reports is the best biased opinion out there.
Old 01-10-2010, 10:12 PM   #3
Thanks...
I went to the .gov site, and according to their maps, we should get good-very good reception.
Thanks again,
Bill
Old 01-11-2010, 07:45 AM   #4
gregzoll's Avatar
Antennaweb.org is another site that helps in knowing strength. Keep in mind, Digital in some areas is a weaker signal, so even if you have a high tower, and large enough antenna, some far distant channels may not always come in, and will Pixelate.
Old 01-11-2010, 08:04 AM   #5
the Musigician
DangerMouse's Avatar
boy, you can say that again.....
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 01-11-2010, 12:06 PM   #6
I noticed all the converter boxes I could find locally have only a composite output, but composite doesn't work well with my TV, which has an HDMI input.
I got a DVD recorder with a digital tuner. No converter box necessary.
pyper is offline   Reply With Quote
Old 01-11-2010, 12:22 PM   #7
Your TV has a HDMI input but not a digital tuner?
jerryh3 is offline   Reply With Quote
Old 01-11-2010, 01:11 PM   #8
gregzoll's Avatar
That would be because if a set has a ATSC or QAM tuner, you do not need a ATSC OTA converter box.
Old 01-11-2010, 01:18 PM   #9
Yes. For some period of time before they finalized the digital broadcast standard they were selling HD sets with analog tuners and HDMI input.
Old 01-11-2010, 07:34 PM   #10
gregzoll's Avatar
They still do. All sets still come NTSC/ATSC/QAM tuners.
Old 01-11-2010, 08:41 PM   #11
What question are you answering?
Old 01-11-2010, 10:27 PM   #12
gregzoll's Avatar
Look one above the one that you are questioning.
Old 01-12-2010, 05:24 AM   #13
OK. I thought you meant that they ONLY come with analog tuners.
Old 01-12-2010, 07:55 AM   #14
gregzoll's Avatar
TV sets have not come with Analog only tuners for around 5 years now.
DIY AC to DC power converter? hefty Electrical 9 11-16-2009 09:20 PM
Digital Converter Box otbelite1 Home Theater 3 05-05-2009 06:56 AM
uhf/vhf antenna does not plug into converter box. why? zz1234 Home Theater 6 04-14-2009 05:28 PM
converter for 4 to 5 inch for dryer vent tetrisattaque HVAC 1 01-13-2009 01:02 PM
3 Phase Converter Wiring ideffects Electrical 22 05-26-2008 09:05 PM
