Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Home Theater
Old 12-31-2011, 06:17 PM   #1
is there a TV wall mount with vertical adjustment?
I'm looking for a TV mount with vertical adjustment so I can hang a TV above a fireplace and drag it down when I want to watch TV. I know that having it permanently above the fireplace is a bad idea since it means that we'd get a kink in our neck from the bad viewing angle but it doesn't make sense to keep it on the ground blocking the fireplace. Also, I can't really put it elsewhere in the room because of the general layout of the room (2 doors on 2 other walls and big windows on the last remaining wall).
I found one place, here....
www.dynamicmounting.com
but at $500 + shipping it's a bit pricey since most other mounts are ~ $150-ish.
any ideas?
MLMIB is offline   Reply With Quote
Old 12-31-2011, 06:57 PM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
You are not going to get anything decent for $150. Look on ebay, etc.. A lot of reason why you do not see many mounts with vertical adjustments, is due to after a while a lot of the cheap ones fail, the better ones have securing nuts to stop them from dropping down out of adjustment.
BTW, they are called Articulating TV Wall mounts. http://search.yahoo.com/search;_ylt=...iculating%20tv
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 12-31-2011, 09:42 PM   #3
JOATMON
ddawg16's Avatar
You need to use some caution when mounting above a fireplace....especially if your using the fireplace.....heat.
As for the angle....Ours is above the fireplace....we are NOT using the fireplace right now....tired of cleaning it out...and I live in California...it's not like it gets real cold.....I plan to convert it to gas when I'm done with the 2-story addition.
With that said....why is the angle going to hurt your neck. The below pic is of our fireplace before we installed the TV...the TV is right where the mirror is. Angle is perfect.
Ok.....photobucket is not working....i'll post the pic as soon as they become alive....
Ok...photobucket working now....
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
ddawg16 is online now   Reply With Quote
Old 12-31-2011, 10:11 PM   #4
do you have a picture of with the TV up? how far from the TV is your seating from the TV? just curious what your viewing angle. My seating is fairly close (12 ft) and I might gain 2 ft when I mount it back above the TV but I'm afraid when I mount it above the mantel (it'll be with a base ~5ft up) it'll be to much of a look up.
Old 12-31-2011, 10:54 PM   #5
JOATMON
ddawg16's Avatar
No fresh pictures....but...the TV is EXACTLY where the mirror is....flat panel 40". It is about 12' from the TV to where we sit.
Also note that our fireplace is a bit higher than normal. I would estimate the bottom of the TV is about 5'. Angle is perfect. Our TV mount allows you to angle the TV down....I maybe have it at 10 deg.
If you relaxing on the couch with your head relaxing on the back of the couch....perfect angle...
My
and
Old 01-01-2012, 06:25 AM   #6
Learning Things Every Day
Jay 78's Avatar
Is a projector screen out of the question?
Under Construction
Jay 78 is offline   Reply With Quote
Old 10-27-2012, 05:05 PM   #7
MLMIB, did you find a solution? I too want to do exactly what you've posted and am looking for a good way to do it. Was thinking of a custom arm system that would allow the tv to pull out and extend down for daily viewing and then slide back up above mantel height for entertaining etc. Would love to see what you came up with!
Thanks!
timbozi is offline   Reply With Quote
Old 10-27-2012, 05:33 PM   #8
GBrackins's Avatar
timbozi,
welcome to the forum!
one area of caution is the warranty on your tv. typically installing a tv above a fireplace will void your warranty as the heat plays heck with the electronics. if you must do this make sure to have a deep mantel in an attempt to direct the heat away from the tv above.
Good luck!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is online now   Reply With Quote
Old 10-27-2012, 09:57 PM   #9
Originally Posted by GBrackins View Post
timbozi,
Good luck!
Sorry, but I'll have to disagree with this one. Show me where it says that in the warranty....
The worst thing I see is these guys advertising on Craigslist, and the like, that will mount your flat panel for $99.00.
Power cords run in the wall, etc, etc. All illegal and dangerous. None of these guys have any insurance, so if something does go wrong, you're out of luck. They get hurt while on your property, you are responsible for their medical bills forever.
Ask yourself, would you hire a doctor to do a heart transplant that advertised on CL?
That said, you would want a professional that will not only mount the panel, but will include power surge protection, something other than a cheap Chinese mount, as well as have proof of liability and workers comp insurance...
Cheap isn't the way to go with this kind of stuff.
ktkelly is offline   Reply With Quote
Old 10-27-2012, 10:17 PM   #10
GBrackins's Avatar
it's ok if you disagree with me .....
I did not say all tv's (maybe there are some out there made specially for this type of installation) I said typically ......
you should follow the installation and safety instructions provided by the manufacturer when installing your tv.
Gary
Old 10-28-2012, 04:44 PM   #11
Thanks for the heads-up guys. Living in San Diego, i'm not too worried about using the fireplace
Just trying to find that balance between form & function!
Old 01-12-2013, 05:48 PM   #12
I recently mounted my TV with the Down and Out mount from http://www.DynamicMounting.com
I mounted it on my fireplace and this was the only option that I found for adjusting the TV vertically. It's a great mount
leonharthagans is offline   Reply With Quote
Old 01-13-2013, 02:42 AM   #13
747
registered
747's Avatar
Nice legs and mantle on your fireplace
747 is offline   Reply With Quote
Want to mount a sconce on the wall where there is a stud pdp76 Electrical 24 04-01-2011 06:07 PM
Need help with how to mount porch light to concrete foundation wall wherm5150 Electrical 7 11-16-2010 09:56 PM
Removing built in drywall shelves to wall mount TV homerb Project Showcase 0 05-19-2010 01:34 PM
Wiring for a wall mount flat screen Badfish740 Electrical 4 01-13-2010 08:21 PM
How to mount an enclosure to exterior wall with vinyl siding? biglaz Building & Construction 3 05-30-2009 11:13 AM
