Terminating Cat 5 Cables - Home Theater - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Home Theater
Old 08-29-2009, 08:34 PM   #1
We had an intercom system prewired but did not install the IC. Now I want to do it. What type of connector do I need to terminate and connect the CAT 5 wiring(I think it is Cat 5 anyway)
bohaiboy is offline   Reply With Quote
Old 08-29-2009, 10:09 PM   #2
It will depend on the Intercom. Do you have the model numbers?
jerryh3 is offline   Reply With Quote
Old 08-30-2009, 07:38 AM   #3
Remodeling Contractor
what type of connection is available on the units. RJ 45 is used for networking computers and other equipment you need a crimping tool or punch tool depending on which way you go for the fittings needed. You could also just need small stacons if the equipment use a screw down block. Possible to use only a punch down block also.
Old 08-30-2009, 08:34 PM   #4
It uses RG46 according the manual. Does that make since and what tools would be needed for that.
Old 08-30-2009, 08:35 PM   #5
Sorry RJ46
Old 08-30-2009, 09:32 PM   #6
Originally Posted by bohaiboy View Post
Sorry RJ46
Does this use 10 wires? You may need 10P10C connectors. I don't believe RJ46 is an "official" plug type. They may just be referring to an 8P8C RJ45 that uses all eight wires. Can you post the model number of the intercom.
Old 08-30-2009, 10:25 PM   #7
On-Q IC1002
Thanks for the help.
Old 08-30-2009, 10:32 PM   #8
Minimum cable rating: Category 5 UTP, 4 pair solid conductors (24 AWG),
100 ohm, 100 Mhz, General Purpose (CM), UL listed
Maximum length per run: 325 feet
Termination standard:T568A
Terminating plug type (where necessary): Solid Conductor RJ45
Terminating block type (where available): 110-style IDC
Wiring Guidelines
• Do not exceed 25 lbs. of force when pulling cable.
• Do not splice cables.
• Do not staple cables. Use wire ties with screw mounts to loosely secure
cabling.
• Avoid running Cat 5 cable parallel to 120V/240V AC wiring or fixtures within
12 inches.
• Avoid “ganging” any intercom unit with a lighting dimmer switch. Maintain at
least 12 inches of separation from dimmer switches.
• If you must cross AC wiring, do so at 90 degree angles and maintain at least
2 inches of separation.
Intercom Module Main Console Unit Indoor Room Unit
Door Unit
Door Chime
Old 08-31-2009, 01:43 PM   #9
these are standard network cable connections. Home Depot has them
Old 08-31-2009, 01:49 PM   #10
Thanks Bob
Help! Need way to locate low voltage light cables Johnboy555 Electrical 17 01-13-2017 02:34 PM
RG-6 near electrical cables Randell Tarin Home Theater 17 05-22-2011 07:51 PM
Ceiling fan sway cables?? johnatjhu Electrical 4 08-02-2009 12:31 PM
Does the insulation on old SER cables ever fail? jamiedolan Electrical 4 03-01-2009 12:03 AM
routing cables through walls and attics cannouu Electrical 18 04-10-2008 07:53 PM
