Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Home Theater
Old 06-11-2012, 09:04 PM   #1
Television help
Good Evening,
I apologize if this has been covered elsewhere but I searched without much luck. We are converting our basement into a play area for our kids. We've hung a tv on the wall but here is our dilemma. We don't have the ability to get cable in our basement without an expensive hookup that would require drilling. The cable company has been out and there is no line (even though the guy we bought it from put something in that looks like a cable jack that ultimately leads to nowhere), we've looked at the wireless options and the feedback we received was that due to plaster walls and the crawl space the signal would be too weak. any suggestions?
thanks
mark092974 is offline   Reply With Quote
Old 06-11-2012, 09:18 PM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
Television help
Run the coax along the top of the wall and ceiling, and paint it the same color as the wall. done like that all of the time. Or run in either conduit, or panduit, if you want to protect it a little. The choice is yours.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 06-19-2012, 09:56 AM   #3
Coconut Pete's paella!
CoconutPete's Avatar
Television help
How far from the TV is the nearest cable? You managed to hang a TV on the wall .... put your mind to it and you'll be able to do this.
CoconutPete is offline   Reply With Quote
Old 09-09-2012, 01:06 AM   #4
awd
Television help
your cable should/probably come in from the basement.... track it down, go outside the house and find where tje cable come in ?
awd is offline   Reply With Quote
