Surround Sound Delay - Home Theater - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Home Theater
Old 07-06-2011, 11:09 PM   #1
Missouri Bound's Avatar
Surround sound delay
When using my Directv receiver with my surround sound, there is a delay which makes the actors lips out of sync. But when I play a DVD there is no delay....any thoughts?
Old 07-07-2011, 07:09 AM   #2
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
Are you using HDMI from DTV to Stereo Receiver?
or are you going DTV audio to stereo receiver and DTV video straight to TV?
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 07-07-2011, 05:32 PM   #3
MR Chips.... My stereo receiver does not have HDMI connections. My Directv receiver is connected to my television, 55" Phillips flat screen LED with a HDMI connection. MY Directv receiver is connected to the surround sound receiver with RCA (red and white) cords. The DVD player is also connected to the receiver with the RCA cords.
Old 07-07-2011, 06:51 PM   #4
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
Take a look at the surround settings on your Stereo reciever for both the DTV and DVD. Maybe you are using a different surround sound mode as the default for each of these.
Try different settings, see if your receiver has a menu setting for room size or speaker distance
If the surround sound for the dvd is working fine, try this: unplug the component cables from the back of the DVD player, and plug them into your DirecTV receiver. Then watch Directv with the receiver set to DVD. Did you still notice the delay?
Old 07-14-2011, 08:17 AM   #5
Thread killer
Rewards Points: 272
Is it all the channels or just a few? I ask because I have run into the problem with a few channels, not all of them. Unfortunately, the only fix is to set the delay on my receiver. When I do that though, the other channels end up out of whack and have to set it back because the delay is set for the receiver input and not the individual channels.
Canucker is offline   Reply With Quote
Old 07-14-2011, 03:35 PM   #6
Unfortunately it's all channels.....
Old 07-14-2011, 08:26 PM   #7
Thread killer
Rewards Points: 272
It's not necessarily a bad thing, provided your receiver has the ability to compensate for it by delaying the audio. If it does, set it until it looks right to you. If you can't, then you'll have to find out what processing is being applied to the signal(possibly upscaling from the directv box) and turn it off, if you can. It takes time to add something to the signal, thats usually why its out of sync.
Surround Sound Hookup Options Branden Home Theater 3 10-06-2010 03:40 PM
best way to wire rear surround sound speakers brewmastr Electrical 5 01-10-2010 07:37 AM
Surround Sound Install jburd964 Home Theater 4 01-08-2010 05:11 PM
What makes a quiet window? Badfish740 Building & Construction 8 09-30-2007 11:22 AM
wiring for surround sound? starnz General DIY Discussions 2 12-20-2006 09:13 PM
