Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Home Theater
Old 01-15-2012, 02:56 PM   #1
Surround sound..
I have a samsung Surround system. The layout of my living room makes it very hard to get a nice set up going with the speakers. I have no way of running wires to get my rears to be behind the couch. I know they make the wireless add on that could help me out but does anyone know exactly how it works??? Do only the rears hook up to it or is it mids and sub too?
Ckb3216 is offline   Reply With Quote
Old 01-15-2012, 03:17 PM   #2
Learning Things Every Day
Jay 78's Avatar
Surround sound..
Check this out: http://www.samsung.com/us/article/wh...less-speakers-
Why can't you run the wires?
Under Construction
Jay 78 is offline   Reply With Quote
Old 01-15-2012, 03:27 PM   #3
Surround sound..
Well cant say "i cant" but its not my strong field...i dont see where i could hide the wires..
Old 01-15-2012, 05:07 PM   #4
Jay 78's Avatar
Surround sound..
Do you have a basement?
Under Construction
Old 01-15-2012, 09:48 PM   #5
Surround sound..
No basement, no attic, no crawlspace
Old 01-16-2012, 02:06 AM   #6
Thread killer
Surround sound..
Would need to see the layout of your living room, but if you're comfortable doing the work, they can be hidden behind baseboards.
Canucker is offline   Reply With Quote
Old 01-16-2012, 09:55 AM   #7
Surround sound..
on mine i just poked the wires along the base board push them in the wires will go under the base boaed. Their is a tack strip that the carpet is held by the tack's. and than base board is put on so their should be enough room. No when you come to a door way i took off the door molding and put wires in their. I built my house so no problum doing this. It take's a little time but it work's . I have the bose system and harmon karden unit.
del schisler is offline   Reply With Quote
Old 01-16-2012, 04:45 PM   #8
Surround sound..
Ya its hard for me, i have my living room open to my kitchen/diningroom so i dont have a wall to run a wire against and i dont have a wall to wall carpet to hide it the right rear i was able to run in baseboard and behind my couch as for left, i cant figure a way
Old 01-16-2012, 05:47 PM   #9
Surround sound..
Attic by chance?? if so you may have to run the wires from the attic down in the corner's to speakers ?? The sound isn't balance out good if you can't get the speaker's set right.
Old 01-16-2012, 06:18 PM   #10
Jay 78's Avatar
Surround sound..
Originally Posted by del schisler View Post
Attic by chance??
Post #5.
Can't go above. I asked about a basement to see if he could go under the floor. No dice there, either.
Under Construction
Old 01-17-2012, 08:20 AM   #11
Surround sound..
Originally Posted by Jay 78 View Post
Post #5.
I did a search for wireless speaker transmiters and found these check and see if any of these will do the Job sorriy forgot about attic after the post i did. but check this out http://www.google.com/#sclient=psy-a...iw=978&bih=561
Old 01-17-2012, 07:05 PM   #12
Thread killer
Surround sound..
Keep going under the baseboard until you get to the spot you want to put your left speaker. It'll follow the same path you've already run. It'll just be longer
Old 01-18-2012, 12:24 PM   #13
Surround sound..
No can do. My baseboards stop near back of my couch then i have door and staircase, ill have to draw up a layout for you guys
Surround Sound Hookup Options Branden Home Theater 3 10-06-2010 03:40 PM
Surround Sound Install jburd964 Home Theater 4 01-08-2010 05:11 PM
What makes a quiet window? Badfish740 Building & Construction 8 09-30-2007 11:22 AM
wiring for surround sound? starnz General Discussion 2 12-20-2006 09:13 PM
laminate flooring & surround sound Susan General Discussion 7 06-12-2005 12:43 AM
