Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Home Theater
Old 09-28-2009, 06:59 AM   #1
Red face
subwoofer has no sound
just bought speakers and subwoofer. connected cable from subwoofer out on receiver to subwoofer but no sound -- the sub is on because the light is on. Of course I plugged it into an outlet also...I've tried almost everything but no success...help!! Do the speakers need to be set up before it will work?
lindapalmbay is offline   Reply With Quote
Old 09-28-2009, 07:03 AM   #2
What are the model numbers? Are you sure you have the sub output turned on?
jerryh3 is offline   Reply With Quote
Old 09-28-2009, 07:04 AM   #3
the Musigician
DangerMouse's Avatar
are these for a computer? then yes, they may need to be set up software-wise.
or there may be another knob for volume on the woofer itself!
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 09-28-2009, 07:11 AM   #4
No - this is a home theatre system. I tried the volume button on the subwoofer no dice.
Old 09-29-2009, 03:14 PM   #5
Just as a follow up, I discovered that the receiver's pre-out terminal is not working. Since this is a new receiver, I am returning it. Always something!!!
Old 09-29-2009, 04:52 PM   #6
Newbie Bill
I had a similar problem with our sub woofer on our home entertainment system.
We went away on holidays, came home, sub woofer no worky. I spent a great deal of time fiddling with the reciever and checking the cables. I finally discovered that I had unplugged the subwoofer before I left on holidays. Doh.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 09-29-2009, 07:22 PM   #7
Average Joe/ex-Navy IC3
gregzoll's Avatar
Unless the directions specified to connect to the Pre-Out, normally the Sub connects to your Left & Right Speaker channels, or if the receiver is high end, it will have a Sub output for Front (L/R), Rear (L/R), Surrounds (L/R). Pre-Out is only for a Pre-Amp.
gregzoll is online now   Reply With Quote
Subwoofer picking up noise/signal when ceiling fan is switched on johnharold22 Electrical 2 07-02-2009 06:23 PM
Sound Transfer Through Heating Ducts akimbo HVAC 22 06-25-2009 08:26 PM
constant running water sound gmk2008 Plumbing 9 11-11-2008 09:22 PM
Soundproof Windows BlueJello General Discussion 3 11-30-2007 06:34 PM
What makes a quiet window? Badfish740 Building & Construction 8 09-30-2007 11:22 AM
