Stereo (speakers A & B) From A 5.1 Or 7.1? - Home Theater - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Home Theater
Old 01-02-2015, 07:44 AM   #1
Rewards Points: 50
Stereo (speakers A & B) from a 5.1 or 7.1?
Is there a way to use a 5.1 or 7.1 receiver as a basic stereo receiver (having two pairs, A and B speakers) ? The reason I don't just buy a stereo receiver is because the stereo receivers don't have USB ports for iPod or HDMI input to connect a DVD player (to play CD's).
Thanks for any input on this.
El Buey is offline   Reply With Quote
Old 01-03-2015, 08:35 AM   #2
Rewards Points: 546
Of course. You'll have to dig through all the settings to make sure it is in "stereo" mode -- it may be a mode, or you may have to manually turn off each channel you're not using. Otherwise the receiver will be stripping channels out so you won't hear them as they are designated for channels you don't have connected. But if you set it up correctly -- and EVERY multi-channel receiver will have a way to be set up this way, it's just going to be a pain to find sometimes -- it will work fine.
TheBobmanNH is offline   Reply With Quote
The Following User Says Thank You to TheBobmanNH For This Useful Post:
El Buey (01-03-2015)
Old 01-03-2015, 05:28 PM   #3
Rewards Points: 606
You got the answer in the other thread, so why ask again?
Yamaha Aventage AVR, set the main to stereo, room two will be stereo.
They'll work independently, and you're good to go.
ktkelly is offline   Reply With Quote
The Following User Says Thank You to ktkelly For This Useful Post:
Old 01-03-2015, 06:36 PM   #4
Rewards Points: 50
Actually, ktkelly, the "other" post was posted first and got no answers until today, so I asked again. May come as a surprise to you but not all of us are geniuses. But I still appreciate your input.
Old 01-03-2015, 06:59 PM   #5
Rewards Points: 606
You calling me a genius?
Hot damn!
Old 01-03-2015, 07:47 PM   #6
Rewards Points: 1,996
You can easily turn off channels you're not using on any receiver. But I don't believe that is the question (unless I'm mistaken)...
You can not treat the rear speakers as a speaker set "A" (stereo) and the front speakers as a speaker set "B" (stereo) with any conventional receiver. Now there are more expensive systems that will allow you to do that. It's a multi room feature and I have that and use it. But with a conventional (cheaper) receiver you have to use an A/B switch connected to the mains.
Now maybe I'm misunderstanding and you simply want to run stereo mode on a 5.1 receiver? Any 5.1 reciever has a stereo mode.
Bob Sanders is offline   Reply With Quote
The Following User Says Thank You to Bob Sanders For This Useful Post:
Old 01-03-2015, 08:16 PM   #7
Rewards Points: 50
Thanks Bob. I just want 4 speakers in the same large room playing the same thing. The simplest answer (at least for me) is to go with the 2 channel A/B splitter. I'll get a 5.1 receiver...connect the "front stereos" to the splitter in, then my four speakers to the splitter out. Even a newbie like me can accomplish that. I think.
Old 01-03-2015, 09:56 PM   #8
Rewards Points: 606
Not a good idea if you're going to run four speakers off of the "A" connection, into an outboard switch, and then to the speakers.
Do so, and you're placing a load on the amp that it's not designed for. The result can be pretty bad.
If you're just wanting to run four speakers, simply wire two to the "A", and two to the "B".
Still not great, but it should cause no harm.
Although, the internal amp may well shut down at higher volumes, and possibly suffer an early failure.
Another option is to use one of these:
http://www.ebay.com/itm/Russound-Ss-...item1c4bda3a39
Impedance matching will allow all speakers to be connected to the "A" or primary speaker out, and will protect the amplifier.
Old product, but it should work well.
El Buey (01-06-2015)
Old 01-05-2015, 09:18 AM   #9
Rewards Points: 546
Oh. I guess I misread something or didn't see the other post about this. I thought he was just trying to run a receiver in stereo mode, not DUAL stereo mode.
Plenty of receivers have A & B "zones" where they can both output the same thing in stereo, just do research.
Old 01-05-2015, 11:06 AM   #10
Rewards Points: 142
this pretty much solves it. it is rather simple to switch 5.1 or 7.1 surround sound to stereo though. you can change the settings on the audio driver installed in your computer. it is usually situated near the desktop clock and you will only need to change the modes.
PD_Lape is offline   Reply With Quote
The Following User Says Thank You to PD_Lape For This Useful Post:
Old 01-06-2015, 05:03 PM   #11
Rewards Points: 50
Thanks all. Thanks KT for the warning. Haven't bought anything yet so I'll check out the link you gave. What a pain. If somebody (besides Onkyo) offered a stereo receiver with USB input (iPod) I wouldn't have to go through this.
Old 01-06-2015, 05:26 PM   #12
Rewards Points: 50
http://www.amazon.com/Speaker-Select...YJT6QBR73V8QAW
Stereo speakers Blondesense Electrical 20 06-23-2013 10:16 PM
Home Electrical / Car Stereo Question pjpjpjpj Electrical 4 08-12-2012 07:59 PM
Ideas needed for placement of Stereo Speakers on outside deck/patio mafmmx General DIY Discussions 5 04-07-2012 01:04 AM
Surround Sound Speakers Blondesense Home Theater 3 11-26-2009 08:42 PM
