Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Home Theater
Old 04-03-2009, 02:04 PM   #1
Splitting coax?
I want to run cable to five tv's and one cable modem. What's the best way to split off the coax to run to each of my different rooms. The cable comes into the house from the outside, do I just need a large splitter with one in, and five out? Will this weaken my signal to each? When I upgrade to an HD tv will this affect anything?
Yeti is offline   Reply With Quote
Old 04-03-2009, 04:20 PM   #2
Home Theater Guy
Splitting coax?
What you need to do is use a 2 way splitter to divide the Tv and modem. Then use a 4 way splitter for the TV feeds. As long as the cable co. is giving you the required signal to the demarc, you will be ok.
Greg C is offline   Reply With Quote
hardwood tongue is splitting with nailer atomilano Carpentry 10 05-04-2009 09:05 AM
unwanted voltage on coax sat-man Electrical 4 09-19-2008 08:36 AM
Tips on Running Coax handy man88 Electrical 2 08-29-2008 01:07 PM
Running New Coax modena Home Theater 3 07-18-2007 02:18 AM
Coax cable removal or disconnect RobbC2 Electrical 3 04-14-2007 08:21 PM
