Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Home Theater
Old 02-18-2008, 12:12 PM   #1
speaker wire
if i get more speaker wire and attach it to my speakers will it take away from the quality of the sound?
JAVAMAN is offline   Reply With Quote
Old 02-18-2008, 01:19 PM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
speaker wire
Not really. It can add impediance if kinked or too small of a size. The rule of thumb is, use at least 12-14 awg for Sub-Woofers, 16-18 awg for all other speakers. Think of it like a water pipe going to your house. The larger the pipe, the easier things are going to flow, but too large, the water pressure drops, and takes longer to get there.
And yes, you can use the wire from Radio Shack & Wal-Mart just fine. Just stay away from overpriced cables.
gregzoll is online now   Reply With Quote
Old 03-12-2008, 08:10 PM   #3
Home Media Professionals
speaker wire
Subwoofer ? Powered Sub ? why are you runing line outs to subs ? Try RCA over COAX RG59 --- would give you proper shielding that would cut down on hissssssing.... unless you like the hisss and buzzzzzz.
Home Media Professionals is offline   Reply With Quote
Old 03-12-2008, 08:11 PM   #4
speaker wire
Subwoofer ? Powered Sub ? why are you runing line outs to subs ? Try RCA over COAX RG59 --- would give you proper shielding that would cut down on hissssssing.... unless you like the hisss and buzzzzzz. If they are not powered. Then 10 but shielded. But wait maybe they are small subs.....
Old 03-12-2008, 08:40 PM   #5
gregzoll's Avatar
speaker wire
RG-59 is fine and all, but is not going to work in this kind of application. RG-59 is a 75ohm rated cable, and if you are getting Hiss & Buzzing, it is not from the cable to the speaker, but from the setup.
Speaker Wiring JamesA Home Theater 15 02-22-2013 01:42 PM
Running wire to a Ceiling Speaker (in vaulted ceiling) rgmetro Electrical 1 01-09-2008 11:27 AM
Speaker wire leted_82 Home Theater 1 08-29-2007 09:07 PM
Running speaker wire parallel to electrical wire spyguy Electrical 3 02-21-2007 03:10 PM
Flat Speaker Wire Dustin07 Home Theater 3 01-17-2006 10:40 PM
