Soundproofing Advice - Home Theater - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Home Theater
Old 04-15-2012, 03:07 PM   #1
Soundproofing advice
I am building a home band practice studio in my basement and want to soundproof. I have 2 questions.
Since the stud framing will be not attached to the foundation walls, is it necessary to use soundclips on the walls since they are already decoupled? (ceiling will be decoupled)
I am going to use 5/8 Sheetrock doubled up w green glue In between instead of quietrock 525. Should I expect similar or better results than just quietrock?
Moonzy1 is offline   Reply With Quote
Old 04-19-2012, 10:27 AM   #2
Soundproofing Guy
Rewards Points: 158
Hi Moonzy,
#1 You would not use decoupling clips to decouple an otherwise already decoupled wall. Just as you figured.
#2 The damped wall that is the heaviest will perform much better. Two sheets of standard 5/8" drywall is nearly 5 pounds per square foot. The 1/2" product you mentioned weighs 2.7 pounds per square foot. You'll notice this in the bass isolation right away.
Given that you'll have an anticipated 11% drywall waste factor, you can fill the dumpster with $7 a sheet scrap or $50 a sheet scrap.
Ted White is offline   Reply With Quote
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 10:05 AM
Soundproofing kitchen sink? FixItGal Plumbing 2 09-13-2010 08:40 AM
looking for Serious advice and Help on Insulation bfan781 Building & Construction 6 05-19-2010 11:02 AM
DIY Advice Seeker - late 1970 seventies knockdown texture onegative Drywall & Plaster 1 04-22-2010 08:40 AM
Electrical Advice Caution!!! Mike Swearingen Electrical 12 03-05-2008 11:51 AM
