Soundproof Drywall? - Home Theater - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Home Theater
Old 03-28-2009, 11:10 AM   #1
Question
Soundproof Drywall?
Has anyone found soundproof drywall for their media room? I am unable to find it and we live in southern Ontario. I wish to add this to the exsiting drywall to lessen the noise level in the master bedroom. Thank you.
ermickie is offline   Reply With Quote
Old 03-28-2009, 08:59 PM   #2
Rewards Points: 264
National Gypsum makes a product called Soundbreak. It is 2 sheets of drywall with a membrane between. You can also make your own using Green Glue and similar products.
7echo is offline   Reply With Quote
Old 03-28-2009, 09:42 PM   #3
The thicker the drywall, the less sound is transmitted. So if you installed 5/8" drywall over the 1/2" you would have a total of 1 1/8" thickness.
You could fill the stud cavities with blown in cellulose insulation.
When I built my house, I built the bathroom walls using 2X6 top and bottom plates and off-set 2X4 studs.
Then I wove insulation bats in and out before installing 1/2" drywall to close the walls in.
As sound is 'telegraphed' through the studs, using off-set studs provides a 'break' between the two drywall surfaces!
In your case, if space permits, you could build another insulated wall, making sure there is no contact between the two walls and then finish the new wall off with 5/8" drywall.
Old 03-28-2009, 09:51 PM   #4
Home Theater Guy
The best solution is to build a room in a room. No contact between the walls, ceiling, and a membrain between the floor and the base floor.
Greg C is offline   Reply With Quote
Old 03-31-2009, 06:54 PM   #5
Registered User
Rewards Points: 5,498
I may have posted this before, if so sorry.
http://www.certainteed.com/resources...%20Control.pdf
Maybe it could reference someone else. Be safe, GBR
Old 03-31-2009, 11:32 PM   #6
I've used Green Glue with excellent results. No special drywall necessary, just 28 ounce tubes of green glue.
http://www.greengluecompany.com/
Since you already have existing drywall, you just squeeze 2-3 tubes randomly on the back of the new piece of drywall, lift it in place and srew it up.
I used 5/8" Type X drywall. It has a denser core which even by itself, provides quite a lot more sound deadening than just one sheet of 1/2".
KHouse75 is offline   Reply With Quote
Old 04-05-2009, 12:25 AM   #7
Union Electrician
goose134's Avatar
Great link. I have a friend who could use this. I couldn't find any test data on ceiling retro fits with the green glue. What has your experience been?
goose134 is offline   Reply With Quote
Old 04-05-2009, 02:17 PM   #8
I use the green glue on all the walls and ceilings in all the home theaters I build. you have to plan ahead with hvac pipes and other openings that will allow sound to be transmitted through them.We also use sound isolation clips to hold the drywall off the studs and joists which keeps the sound from transmitting through the studs to the other side.The really low bass vibrations are the most difficult to stop but we have never had to return to a customer location where we used green glue, staggered studs, insulation and sound isolation clips.we just build houses and do remodels and are not expert soundproofers but our customers was reasonable cost with good results and we found the above to work best without breaking the bank.
Old 04-20-2009, 04:14 PM   #9
vectravl400
I've seen this stuff used on one tv show:
http://www.quietsolution.com/html/quietrock.html
It's supposed to be acoustically equivalent to 8 layers of drywall.
vectravl400 is offline   Reply With Quote
Old 05-22-2009, 09:41 PM   #10
Rewards Points: 27
I'm in the process of building a home theater right now. My walls and ceiling are all decoupled from the rest of the house and I will be insulating everything as well as 2 layers of 5/8" drywall with green glue in between.
jailbird371 is offline   Reply With Quote
Old 05-22-2009, 09:51 PM   #11
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Quiet Rock; http://www.quietsolution.com/html/quietrock.html
We've installed it in many locations (some - per engineer design requirements), including Hospitals and Hospital executive offices (Patient confidentiality concerns), media rooms, private theaters, apts, condos, etc, etc, etc.
It works, especially when installed with sound attenuation batts, and additional sound deadening constrution practices: Staggered framing, acoustic caulking, dampening pads, resilient channel, etc....
- Build Well -
Old 05-23-2009, 12:23 AM   #12
Rewards Points: 27
Look through these articles....great information! I ordered all my decoupling clips from here.
http://www.soundproofingcompany.com/library/articles/
Old 06-14-2009, 08:37 AM   #13
cool, i am friends with the guys that created the green glue company here in fargo. glad to hear it is so well recieved.
gregdonovan is offline   Reply With Quote
Old 06-14-2009, 09:08 AM   #14
Rewards Points: 27
I'm not at the green glue stage yet, but I will definitely be using it in a few months.
Old 05-25-2010, 01:19 AM   #15
AtlanticWBConst. Thanks for the info on quietrock.
And
Their product quietglue is about $35 cheaper than green glue.
I compared their test data, they are kind of the same.
So why pay extra money.
JoanaC is offline   Reply With Quote
Superior Walls - Floating Corners & Drywall Woodcutter Drywall & Plaster 16 04-22-2011 12:05 PM
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 10:05 AM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 01:12 PM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 07:11 AM
