Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Home Theater
Old 09-19-2008, 10:41 AM   #1
Silly problem with TV remote control
Everything on the remote works just fine EXCEPT for the up/down sound adjustment button. I keep pointing the remote toward the TV at different angles, but it just won't work for some reason. Ever heard of this happening before??? By the way, the batteries are fine. In fact, I put new ones in just in case that was the problem.
proofer is offline   Reply With Quote
Old 09-19-2008, 10:48 AM   #2
I have gas!
Clutchcargo's Avatar
Is it a universal remote? Sometimes they loose the memory and need to be re-programed.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 09-19-2008, 10:53 AM   #3
I'm not sure if it's a universal remote or not (I'll check when I get home). But if it needs reprogrammed, wouldn't the other buttons be affected (channel, etc.) as well? Another thing I should have mentioned is that this problem had been getting progressively worse over time---from having to hit the sound button more and more times in order to get it to work, to how it is now---not working at all.
Old 09-19-2008, 11:09 AM   #4
I have gas!
If it's been getting progressively worse, I'd say it's time to spring for a new remote. The contacts inside the remote may be getting burned or dirty.
For my universal remote, if I don't get the code correct for my specific TV, some but not all the buttons work. There can be several different codes for one brand of TV.
Old 09-19-2008, 11:34 AM   #5
bofusmosby's Avatar
Its a common problem. Usually if effects the buttons you use most. Over a period of time, some "gunk" will work its way into the remote, and sometimes, a good cleaning will take care of it.
bofusmosby is offline   Reply With Quote
Old 09-19-2008, 07:20 PM   #6
I've had this problem too. I did as bofusmosby said and had to take one of my remotes apart to clean it. Once I did, it worked fine for a long time. It was the remote that came with the tv.
kjwoodworking is offline   Reply With Quote
Old 09-19-2008, 07:22 PM   #7
Thanks, guys, for the tip. It sounds like a cleaning is in store. I'll give it a try and will post back the results.
Old 09-23-2008, 10:20 PM   #8
Send a message via Yahoo to fburke
try all codes for your brand of tv first if that doesn;t work or if it did use to work pop the back off and go to Radio shack and get a can of electrical contact cleaner spray that on it let it dry and get all the smooge out of it.
fburke is offline   Reply With Quote
Old 09-24-2008, 08:27 AM   #9
bofusmosby's Avatar
As far as the contact cleaner goes, make sure that it leaves no residue. Contacts should be completely dry when cleaned.
Missing Wireless Remote - Motorized Plasma TV Lift JanFan Home Theater 3 03-19-2009 09:46 AM
Stymied by window leakage problem. Matth3w General Discussion 5 06-11-2008 07:26 PM
Carrier furnace blowing control fuse Protean HVAC 3 02-18-2007 07:47 PM
need to control remote lamp post timalabim Electrical 3 05-01-2006 11:40 AM
