#1 |
setting up living room, need advice
ok so i just bought my frist house and im in the process of setting up my current surround sound and tv. this is my situation.
- Living room is 16.5 feet x 14.5 feet. - tv is sony 46 in lcd going on wall - i have a table which is what is going to hold my components. - 5 channel denon surround sound. Questions: 1) left/right and center speakers on table or wall? i was leaning more towards the table. 2) the sub goes by the table by the tv or on the wall by the couch by the rear speakers? |
#2 |
Average Joe/ex-Navy IC3
Really depends on you. As for the sub, you can have it up front, to the side, or rear, depending on your tastes.
#3 |
Theres more then one way.
I would say speakers on the wall with mounts that let you angle them both horizontally and vertically (fronts and surround).
I currently have a couch on the back wall with the surrounds over it and wish i could move the speakers back farther so they are not over my head. The center speaker under under TV sounds best to me. What Denon do you have ? About two years ago i bought a Denon 2807 but its in a small room right now and can not really utilize it. _
. ~ What was once an opinion, became a fact, to be later proven wrong ~ My current learning experience - To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. - Work shop, music-room, master bedroom above.. |
#4 | |
setting up living room, need adviceQuote:
#5 | |
I personally would like the surround speakers farther back to get more of an effect - like when a plan flies over head in a movie or a car drives by, etc. It seams like you have a newer av unit then i do, you should be able to adjust the speakers volume for your surrounds so they are not over bearing. Something i was gonna try but never got around to it was placing the surrounds on the floor facing the back wall so the sound would bounce up the wall. Not sure how it would work, but for the current room my system is in, it was something i wanted to try when time permits. For months i had the surrounds mounted on the back wall, flat, facing foward. Recently i bought those mounts which let you swivel the speaker in all directions and i like that much better, plus it gives better sound for the two chairs in front of the couch. Anyway, if i was you the first thing i would do it play around with the speakers volume through your AV's config/set-up, might help you find the sound you like. _ _
| Display Modes | |
| Skylight opening/portal through living room ceiling | ControlTech | Building & Construction | 6 | 01-05-2009 08:33 PM |
| Living Room Restoration | Angel241 | Project Showcase | 34 | 10-05-2008 11:37 AM |
| Hardwood flooring - 3 walls and a sunken living room | basledder | Flooring | 1 | 12-09-2007 06:34 PM |
| Raising step down living room questions | phil. | Building & Construction | 8 | 08-29-2007 09:49 AM |
