Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Home Theater
Old 11-10-2012, 10:31 AM   #1
samsung TV and mount? any help?????
I have 37 3/4" from the top of my ceiling to the bottem of my fireplace mantel. I am looking at 2 tv’s the Samsung 55 (without stand) 29")
and the 60 (without stand) 31-7/8". I also would like a full motion wall mount. Yes I understand the 2/3 inches difference, I was more interested in the mount and tilting.
Does anyone have a TV mount that simply tilts without going up? Most I have seen have a “C” style axis the rolls up and down.
Is the 60” possible, and if so can you recommend a mount?
Thanks !!!!
chipraynor is offline   Reply With Quote
Old 04-15-2013, 09:32 PM   #2
Check out Monoprice.com, they have a ton of mounts for really cheap prices. I have probably ordered and hung 30 tv's with their mounts, most of them on tilt mounts. I don't think they even carry the C axis mount you were referring too, their's just simply tilt. The mounts are good quality but lack decent instructions usually. They have mounts for 70" and larger tv's.
harts7447 is offline   Reply With Quote
Old 04-15-2013, 09:39 PM   #3
Challenge Everything!
Deja-vue's Avatar
Harts beat me to it.
I have been buying from Monoprice.com for years, never disappointed.
They have a huge selection of Mounts.
Deja-vue is offline   Reply With Quote
Old 04-15-2013, 09:42 PM   #4
Deja-vue's Avatar
Let me see if I can post this picture:
That is a 65 inch Samsung I mounted at a customer's House using Costco's Mounts.
Cheers,
Old 04-18-2013, 06:28 PM   #5
Some good reads "Why Mounting Your TV Above the Fireplace Is Never a Good Idea"
http://lifehacker.com/5993910/why-mo...er-a-good-idea
Diy_Sandy is offline   Reply With Quote
Old 04-18-2013, 06:40 PM   #6
Deja-vue's Avatar
With all due Respect, I disagree with that Story to an extend.
While some "Fireplace-installs" are really to high for the Viewer, even with the TV tilted downwards some 15-20 degrees, this isn't the Case in my Install in the Picture.
People are sitting some 18-20 Feet away from the Set, and I installed a Full Motion Mount as well, allowing them to move the TV left-center right, etc.
BTW, they never actually used that Fireplace.
samsung tv and samsung wall mount dcj710 Appliances 4 01-27-2012 12:36 PM
Mounting huge TV+sound bar above TV with down&out mount djgrant Building & Construction 6 10-05-2011 02:55 AM
