Running Speaker Wires At Right Angle - Home Theater - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Home Theater
Old 04-18-2013, 05:24 PM   #1
Running Speaker Wires at Right Angle
https://www.icloud.com/photostream/#A7GY8gBYGj1H8L
I will be using a flex bit to drill through the 3 stud along the green line, how do I proceed afterwards?
Thanks!
Sandy
Diy_Sandy is offline   Reply With Quote
Old 04-25-2013, 04:47 PM   #2
Rewards Points: 1,494
What difficulties have you run into or do you anticipate?
Old 04-25-2013, 04:55 PM   #3
My concern will be the flex bit coming out from wall when drilling , since there are drywalls on both the front and back and it is very hard to control the flex bit.
Old 05-14-2013, 12:02 PM   #4
Rewards Points: 20
Have considered using a right angle drill instead? I had a similar situation and I had the flex bit do exactly what your afraid of. I went to the right angle drill and it worked great for what I was doing. I was going up from my basement into my first floor office.
edit: I just looked at your photo and see now what your looking at. My suggestion may not apply.
gec5741 is offline   Reply With Quote
Type of Speaker Cables to use in hot attic megablok Electrical 9 02-23-2012 02:14 PM
running wires / NEC question duhtroll Electrical 6 07-20-2011 03:22 PM
Running wires alongside or through ductwork j_sun Electrical 1 07-13-2011 11:11 AM
I installed a new thermostat and the fan will not stop running. The wires are correct TSA0282 HVAC 2 03-02-2009 03:20 PM
Running wires across bottom of joists WaldenL Electrical 8 01-25-2009 03:00 PM
