Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Home Theater
Old 09-04-2011, 10:34 PM   #1
Running speaker wire through the ceiling
I'm about to run speaker wire through my ceiling. I'm in a condo and I have it on good authority that I have independent ceiling joists such that there is enough space above them that I can run the wire over them, rather than cutting holes at each joist, between the speakers and the wall (my joists run parallel to the wall where the tv is).
Anyhoo, my question really is, I was marking out the joist locations using a stud finder and it appears that my joists are 3" or so in thickness. I was a little surprised by that as I would have thought the joists would be 2 x something's. Is it possible that they would be 3"? Could they be double joists? Is that a thing?
Thanks!
Justin
justinmiller621 is offline   Reply With Quote
Old 09-05-2011, 03:26 AM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
Wireless speakers have come a long way. Need to post pictures of what you are seeing.
Old 09-05-2011, 08:57 AM   #3
I haven't actually cut into the ceiling yet so there are no pics to post of that. The only ones I could post would be where I marked off the location with the stud finder, but would that be helpful?
Also, my room is setup such that the back of my couch is in the middle of the room and there would be no power outlet nearby to power the speakers.
Justin
Old 09-05-2011, 11:11 AM   #4
gregzoll's Avatar
Draw up the room in Google Sketch-up and post back here. How high is the ceiling from the floor? And do you have any lighting by the couch? There is actually safe electrical that you can use on floors under rugs, such as used in office buildings. This is what I was talking about. http://gizmodo.com/gadgets/wired-wor...int-256691.php
Old 09-05-2011, 12:57 PM   #5
I'll do that soon. Thanks.
In the meantime though, one question I have is, is it possible that I have 3" thick joists? Is that common? Or is it possible that there are double joists?
Justin
Old 09-05-2011, 01:25 PM   #6
gregzoll's Avatar
You do not have 3" joists. How was this structure built, and how old is it? Is it a multi-level structure (ie more than 2 floors), and where is it located (ie what city)?
Old 09-05-2011, 02:11 PM   #7
It's a 4-story condo building in Baltimore built in 2008 I believe.
Old 09-05-2011, 02:11 PM   #8
gregzoll's Avatar
What kind of material is the structure built out of?
Old 09-05-2011, 02:18 PM   #9
Sheetrock and wood studs (I know that for a fact since I've cut other holes). Was that the answer you're looking for?
Old 09-05-2011, 03:48 PM   #10
I think you should describe more fully what you are wanting to do. If you are looking to do surround sound, give more detail.
For example, inexpensive cove molding can be run at floor level (bare floors). The 90 degree back can be sanded/cut off so speaker wire is run right where wall meets floor. Then you only need 2 (or more) vertical runs up the wall between studs. Your condo won't come after you if you do a neat job and leave wiring in place for next owner.
diyorpay is offline   Reply With Quote
Old 09-05-2011, 05:59 PM   #11
gregzoll's Avatar
Your studs should be 2x4, possibly 2x6, joists could be 2x8 or 2x10. What you may be seeing, especially on the walls, is the members, where they did a offset, to try to keep noise from migrating between units. Also can be done on ceilings.
Adding ground in old home ChaosTheory Electrical 6 06-16-2010 05:02 PM
how to detect an open wire end in the ceiling? tmai Electrical 3 11-17-2009 12:27 PM
Speaker wire in walls LeviDIY Home Theater 12 11-07-2009 03:56 PM
wire ceiling fan to outlet switch((help)) tommy281 Electrical 10 11-02-2009 10:15 AM
Old ceiling replacement idsp General Discussion 12 07-25-2009 11:48 AM
