Romex As RG6 - Home Theater - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Home Theater
Old 10-10-2007, 04:48 PM   #1
Romex as RG6
I'm planning on moving my Satellite dish to the detached garage for a better view of the satellite. I have an unused underground 10/2 romex already buried from the house to the garage. Does anyone know if I can cut and splice my RG6 onto the romex or do I have to dig a trench to bury a new RG6 from the garage to the house?
Thanks, Steve.
Steverino is offline   Reply With Quote
Old 10-11-2007, 08:55 AM   #2
Hi,
If you mean standard 10awg power cable.....No. That cable has no sheilding and essentially no dieletric. Your receivers would pickup no signal or so little it would hardly register.
sorry.
renfrey is offline   Reply With Quote
Old 10-11-2007, 10:00 AM   #3
Steverino,
I would dig the ditch, This is a good thought but will never work. signal quality will never be strong enough. Also most Satellite dishes need two rg6 cables to work correctly. question for you, Is the 10-2 cable in a conduit pipe? or is it just in the ground. If its in a pipe the try to fish your RG6 cable in the conduit. If not instead of burying the cable alone bury a conduit. It makes the cable last longer and also if you need to run something else out to the garage you dont have to dig up your lawn........
jscholl411 is offline   Reply With Quote
Old 10-11-2007, 11:34 AM   #4
47_47's Avatar
Rewards Points: 50
I would not bury any communications cable (telephone, RG6 ...) in the same conduit as power cables. You will get interference.
47_47 is offline   Reply With Quote
Old 10-11-2007, 12:01 PM   #5
I was only suggesting that because i figured that the power cable was dead due to fact that he wanted to use it as a cable tv cable.........
Old 10-11-2007, 12:08 PM   #6
47_47's Avatar
Rewards Points: 50
If that is the only cable in the conduit, I would use jscholl411's suggestion, but use the 10-2 romex to pull all cables through the conduit. I would also pull a few phone lines to the garage. You could operate a garage door opener from the house with one.
Old 10-11-2007, 03:18 PM   #7
If you pull some nylon string with all that you would also have the availability to pull something else through in the future, should the need come up, and depending on the conduit size.
Old 07-24-2009, 09:02 PM   #8
Cool
Romex as RG6
The reason you can't do this is that coaxial cable is designed with a certain impedance(75 ohms) the Romex cable is not designed to have any certain impedance. Without this impedance you would have a mismatch and you would experience probably close to 100% loss(no signal at the other end)
There are devices called baluns (balanced to unbalanced impedance) commonly found on rabbit ears where the twin lead plugs into that little black box and then that black box plugs into the TV. That box is the balun that has 300 ohms coming from the twin lead and 75 ohms for the TV.
Theoretically if romex had a set impedance you could use a balun at both ends and make it work but it would still have a lot of loss.
Hope I gave some not too technical back ground on the subject.
Regards,
Mike KB1CHQ
hamradioguy is offline   Reply With Quote
Old 08-29-2009, 01:05 PM   #9
Cool
Romex as RG-6
Sterverino
Listen to those guys, DON'T USED ROMEX!
technical info: the cable your looking at I hope isn't romex or called NM, and I hope who ever installed this cable used UF cable. This cable has an outer gray jacket, were romex outer jacket could be white, black, blue, and now new #10 wire. comes in the color orange. Be it 10-2 or 10-3. Romex cable also has a paper filler right underneath its outer plastic jacket.
Ranger31 is offline   Reply With Quote
Allowed to run more than one romex cable through a single hole in a joist? J187 Electrical 7 08-17-2007 08:46 AM
Romex laying across joist in attic? Doug Crf Electrical 4 08-17-2006 04:53 PM
Running Romex in the attic mdalli Electrical 7 07-06-2006 05:35 PM
Pulling romex thru wall with old romex? Doug Crf Electrical 4 04-11-2006 09:33 AM
Romex to BX fifaboy Electrical 1 02-27-2005 04:12 PM
