#1 |
RG6 coax question??/
How important is it to get quad shield coax? How important is it to get solid copper instead of copper clad?
I have a 1000' of a brand called vextra which is supposed to be pretty good stuff. It is solid copper rated at 3Ghz. It is not quad shield though. Any of you experts care to comment. I will get different if I need to. I already have the cable and got it for almost nothing. What would you do? Last edited by ingeborgdot; 03-14-2009 at 08:56 AM. |
#2 |
I have been checking and there are soooo many contradicting articles and reports on all of this stuff.
#3 |
Home Theater Guy
In a residential setting, as long as you are not near any radio or TV transmission towers, you will be ok. Just don't run it parrallel to the main electrical feeds. By the way Vextra is a budget wire, but as long as all you are using it for is a RF cable feed, it will be fine.
#4 |
It depends, I used quad and found a slight benefit, but this was old work near a lot of ac wires.
#5 |
Xtreme DIY'r
If you have it I'd use it
I needed some & it wasn't much more to buy quad so I bought quad |
#6 |
I worked for comcast for 7 long years. As long as it is rg-6 it does not matter if it is quad shield or not unless you live in a 12,000 square ft. home and have a really long run you should be good. The aluminum shield is actually better then copper. That is what comcast uses. bbradley@gmail.com
#7 | |
RG6 coax question??/Quote:
In a 12,000 sq ft home I would probably use several distribution points with RG11Q running to them. |
#8 |
Zack Morriss
The GHz rating of the coax is good to know. Typically for most residential applications you will not need the coax to be over 1 GHz. If you have 3 GHz coax go ahead and run it. Again the quad shield will not typically need to be installed in most residential. I have had to use some beefy coax, 3GHz, strictly for HD-SDI applications which is still rather new technology, i.e. Endoscopy equipment in medical OR's, where they are running an 1080p signal over a single coax. Might be a good thing to have the 3 Ghz in your home. Who knows what the future will hold.
| Display Modes | |
| Basement Renovation Question | KUIPORNG | Remodeling | 234 | 08-26-2008 09:19 AM |
| Basement vapor barrier question | rob7young | Remodeling | 2 | 04-13-2008 10:10 AM |
| New service Question | Onytay | Electrical | 1 | 10-24-2007 06:47 AM |
| One furnace question and one thermostat question | lh0628 | HVAC | 4 | 10-11-2007 11:17 PM |
| Welding / faceplate modification question (see pics!) | joeyboy | General Discussion | 17 | 09-23-2007 06:54 PM |
