-   Home Theater (http://www.diychatroom.com/f12/)
-   -   RG6 coax question??/ (http://www.diychatroom.com/f12/rg6-coax-question-40288/)
ingeborgdot 03-13-2009 11:17 PM
How important is it to get quad shield coax? How important is it to get solid copper instead of copper clad?
I have a 1000' of a brand called vextra which is supposed to be pretty good stuff. It is solid copper rated at 3Ghz. It is not quad shield though. Any of you experts care to comment. I will get different if I need to.
I already have the cable and got it for almost nothing. What would you do?
ingeborgdot 03-14-2009 07:56 AM
I have been checking and there are soooo many contradicting articles and reports on all of this stuff.:confused1::confused1:
Greg C 03-14-2009 01:52 PM
In a residential setting, as long as you are not near any radio or TV transmission towers, you will be ok. Just don't run it parrallel to the main electrical feeds. By the way Vextra is a budget wire, but as long as all you are using it for is a RF cable feed, it will be fine.
rgsgww 03-15-2009 02:17 PM
It depends, I used quad and found a slight benefit, but this was old work near a lot of ac wires.
Scuba_Dave 03-16-2009 01:13 PM
If you have it I'd use it
I needed some & it wasn't much more to buy quad so I bought quad
Mr. Wallfish 03-21-2009 01:11 PM
rg6 co ax
I worked for comcast for 7 long years. As long as it is rg-6 it does not matter if it is quad shield or not unless you live in a 12,000 square ft. home and have a really long run you should be good. The aluminum shield is actually better then copper. That is what comcast uses. bbradley@gmail.com:jester:
rgsgww 03-21-2009 04:52 PM
In a 12,000 sq ft home I would probably use several distribution points with RG11Q running to them.
MorrissMediaSys 03-23-2009 09:41 AM
The GHz rating of the coax is good to know. Typically for most residential applications you will not need the coax to be over 1 GHz. If you have 3 GHz coax go ahead and run it. Again the quad shield will not typically need to be installed in most residential. I have had to use some beefy coax, 3GHz, strictly for HD-SDI applications which is still rather new technology, i.e. Endoscopy equipment in medical OR's, where they are running an 1080p signal over a single coax. Might be a good thing to have the 3 Ghz in your home. Who knows what the future will hold.
