RG-6 Near Electrical Cables - Home Theater - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Home Theater
Old 03-29-2011, 06:43 AM   #16
A 5-inch separation should suffice. There is no code on running cable beside the power, HOWEVER if voltage gets onto the cable it can cause a HUM bar in your picture so it is always good practice to separate power and cable.
d4nieL is offline   Reply With Quote
Old 03-29-2011, 08:47 AM   #17
fabrk8r's Avatar
Old posts never die, they just get a lot of new wrinkles.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 05-22-2011, 06:51 PM   #18
tonystewart1's Avatar
I have installed Sat and Cable TV for 10 years and my best advise it to keep your coax as far away from electical as you can. You have no idea how many wall fishes I have had to do to get rg-6 away from electical lines. Huge pain in the you know where.
tonystewart1 is offline   Reply With Quote
Can a homeowner perform electrical work in MA? dpd512 Electrical 77 04-11-2012 06:48 AM
routing cables through walls and attics cannouu Electrical 18 04-10-2008 06:53 PM
Please Help - Weird electrical issue affecting home network sxpsxpsxp Electrical 23 02-03-2008 11:42 AM
OK to put electrical outlet into storage area under stairs? melanie_s Electrical 1 12-29-2007 04:09 PM
Code Question: Electrical and plumbing ELurie Electrical 2 08-22-2007 08:55 PM
