RG-6 Near Electrical Cables - Home Theater - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Home Theater
Old 04-12-2008, 07:57 PM   #1
RG-6 near electrical cables
I'm running RG-6 for a satellite feed in new construction. Is there any problem with running it over and around electrical cables?
I wasn't sure if there would be any interference created EMF of the current carrying cables or if the sheilding on the video cable would be sufficient to protect it.
Randell Tarin is offline   Reply With Quote
Old 04-12-2008, 08:37 PM   #2
Try to keep it at least a few inches away. If you have to cross the two, do it at a 90 degree angle.
jerryh3 is offline   Reply With Quote
Old 04-13-2008, 09:39 AM   #3
Rewards Points: 1,456
12" minimum seperation is recommended.
More is better. 90 degree at crossing points is correct.
ktkelly is online now   Reply With Quote
Old 08-05-2008, 05:11 AM   #4
Send a message via Yahoo to fburke
You shouldn’t have any issue unless it’s near a motor or some other type of high power.
if you are concerned make sure you use a QUAD shield cable. Most cables have a foil then the braid than the outer jacket….a QUAD shield has 2 layers of braid and foil. You will need the correct fittings for the cable…90 % of cabling issues is the fittings and being incorrectly cut and sized.
fburke is offline   Reply With Quote
Old 08-05-2008, 06:48 AM   #5
Electrician
Its not a code violation, and I dont know how long and close they would have to be to actually, if at all, give you a problem.
chris75 is offline   Reply With Quote
Old 08-05-2008, 05:52 PM   #6
Fixer-'til-broker
DIYtestdummy's Avatar
Rewards Points: 262
RG-6 is shielded and runs its own power (very small voltage). You should have no interference at all. The only problem I can see is with tight bends - I don't know the specific tolerance with RG-6, but just to thumb it I'd say no less than 4.5 times the diameter of the cable.
"Aw! Why does everything that only happens to stupid people happens to me?" - Homer J. Simpson
DIYtestdummy is offline   Reply With Quote
Old 08-05-2008, 09:55 PM   #7
So the freqs running down the cable are far removed from 60 Hz.
I think it's unlikely because of the freq. separation but if you do have any interference I guess it would be bars running slowly through the pic.
This might be fixed by isolating the RF ground from the power ground, depending on if the install instructs allow this.
Old 08-08-2008, 11:41 PM   #8
Well, I guess you should just run your video cable right along with all the electrical wiring and not worry about it....
Of course, when the wall are rocked and painted, you move into the home and find out that you DO have interference, it won't be an issue because many here have told you it won't be.....
Old 10-12-2008, 04:23 PM   #9
I am officially off this forum, but. . .
you bring up the topic of risk-aversion.
If my advice is to be carved in stone I would respond more carefully or not at all, because I am not risk-neutral or risk-prone.
On another forum a guy wanted an electronic controller to prevent wheelies in a drag race.
It occurred to me that some simple circuit we all designed could be responsible for the injuries/deaths of bystanders.
He found his own solution and we bowed out. Happy ending.
Let's say the HomeOwner tests this parallel running of cables under many circumstances and they all work. Then he/she covers it over with sheetrock, brick veneer, whatever, and some day he/she finds it doesn't work anymore, for whatever reason.
The cost to repair is X dollars. Before it was zero dollars.
Let's say the HO's exhaustive testing covered 3/4ths of the cases, so there is a 1/4 chance that there is some case in the future that will come back to bite the HO.
Convenience now or a 1/4 chance of trouble later? The HO's convenience now is worth money possibly spent in the future. How much?
A coin is flipped: heads, the HO goes to the trouble to test for the remaining 1/4 of the cases. Tails, he/she runs the cables in parallel.
Now, keep increasing the cost of later repairs, $X, from zero dollars on up.
When it makes no difference to the HomeOwner which way the coin lands, then that is the present value of the possible future cost of $X, today, to the homeowner. If it's less than the predicted future cost of wall destruction/recontruction then the HO should run the cables in parallel.
http://www.amazon.com/Making-Decisio...3842538&sr=1-3
I write better posts when I've had a few.
At least, I think they are better.
Old 11-23-2010, 01:09 AM   #10
Rewards Points: 150
For what it's worth. I just ran RG6 coax. into my wall right next to electrical wire to mount a coax. wall plate and have had no issues.
MikeVila is offline   Reply With Quote
Old 11-24-2010, 04:06 AM   #11
RG6 near electrical
Randall
Listen to ktkelly!!!
I can't believe the bad advice you got from some here. There is definitely an interference issue with running RG6 in parallel with electrical. The shielding is not to protect the cable form EMF, it is to maintain the proper impedence and prevent loss of signal traveling down the cable.
Depending on the type of electrical wiring you have, interference can propagate standard a couple inches from the electrical. If you have twisted electrical cable, it is less. If there is any type of bootleg ground (somewhere that neutral and ground are swapped in an outlet-happens more than you'd think) that interference skyrockets.
If you have low quality connections between the TV and anytype of DVD player etc, your problem gets even worse, as they induce voltage that causes rolling bars, etc.
As for the comment on bending, bends that are too tight typically cause "ghosting", you know, the shadow of the picture slightly offset, whereas grounding and EMF issues cause hum bars.
I hope this helps.
Mark C
orangeproav is offline   Reply With Quote
Old 12-20-2010, 08:06 AM   #12
this
I am a lowvoltage systems installer and have installed many CATV systems. We only use QSRG6 for this reason.
rlukas79 is offline   Reply With Quote
Old 01-05-2011, 09:17 PM   #13
The Cable Guy's Avatar
I wasn't sure if there would be any interference created EMF of the current carrying cables or if the shielding on the video cable would be sufficient to protect it.
For satellite there should be no problem...but like has been recommended, try to maintain at least a few inches separation (recommended is 6"...and definitely try to run quad shield RG-6...tri-shield RG-6 will work, but quad shield gives an extra layer of protection). Unlike what others have said, do NOT cross the RG-6 with the power, even at 90 degrees. Skin effect comes to mind along with other issues...read up for some in depth explanations of ingress, skin effect, and signal leakage (all are problematic) here: http://en.wikipedia.org/wiki/Coaxial_cable
If you are running for cable, then you need to get as far away from those power lines as is physically possible if running them between the same stud, make sure you are using compression F connectors (NOT that cheap *ss Radio Shack crimp on or twist on connectors!!!), and tightening the connectors to finger tight plus 1/6th turn at any wallplate, barrel, groundblock, diplexer, or splitter in order to prevent any possible ingress (ingress isn't too likely with new and well shielded cable, but you don't want any chance of introducing ANY voltage or signal interference into lines for cable...it'll cause you a ton of headaches, and has the possibilities of sending stuff back up the return path, which could effect everybody nearby you who is also a cable customer).
Also, make ABSOLUTELY SURE you're system is grounded per NEC codes! Use 10 gauge wire to bond to the house ground...any accidental voltage leakage into your cable lines can quickly become a disaster.
Hope this helps.
The Cable Guy is offline   Reply With Quote
Old 01-05-2011, 09:29 PM   #14
RG-6 is limited to a 2.5" radius bend...any more will cause serious attenuation and signal loss (not to mention it runs the risk of breaking the center conductor...a good rule to remember is "Low can't jump, high can't swim"...meaning lower frequencies will NOT pass through a broken or severely scored center conductor, and higher frequencies do not do well with any sort of water damage). With the way that both satellite and cable are sending signal up coax these days, you need ALL of the cable (braiding, dielectric, and center conductor) to be in good shape in order to pass all your signal through properly.
Last edited by The Cable Guy; 01-06-2011 at 08:36 PM. Reason: Had wrong radius bend listed for RG-6
Old 01-06-2011, 05:36 PM   #15
I would run it at least 12 inches from any power source. If you are crossing power don't run right on top of it. Leave some space. As far as the bend radius of cable grab the cable about 3 feet apart make a large loop with it slowly pulling the ends tighter. Once they cable starts to spread apart from being in a circle. That is your bend radius. Its usually a 10-12 diameter circle using rg-6 coax. Just a sugestion is to run the cable seperate from the electric. It is easier to do know than latter. It may be more work but there's nothing worse then having to repair drywall to get your TV to work. Also I would suggest using solid copper cable as compare to copper cladded as it will give you better results.
First2429 is offline   Reply With Quote
Can a homeowner perform electrical work in MA? dpd512 Electrical 77 04-11-2012 07:48 AM
routing cables through walls and attics cannouu Electrical 18 04-10-2008 07:53 PM
Please Help - Weird electrical issue affecting home network sxpsxpsxp Electrical 23 02-03-2008 12:42 PM
OK to put electrical outlet into storage area under stairs? melanie_s Electrical 1 12-29-2007 05:09 PM
Code Question: Electrical and plumbing ELurie Electrical 2 08-22-2007 09:55 PM
