Receiver To Subwoofer Connection - Home Theater - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Home Theater
Old 05-26-2013, 02:57 PM   #1
Rewards Points: 12
Receiver to subwoofer connection
My receiver just quit on us, and I'm in the market to get a replacement. I'm a bit confused about how our current subwoofer will attach to the new receiver.
Currently our subwoofer connects to the receiver using standard speaker wire. Most of the receivers I am looking into have a black RCA type connections for the subwoofer. I'm not sure how to attach this to my existing speaker. Is this a connection to a separate amplifier for just the sub? If I buy a receiver with this type of output would it be compatible with the inputs on my sub?
Thanks!
vect0r is offline   Reply With Quote
Old 05-26-2013, 03:42 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 1,192
Just use a 'make your own RCA' plug. You can get them at radio shack.
One thing..... Is your sub woofer powered? As in it has a power cord. If not. Then it most likely wont work correctly with a new reciever. With powered sub's you doing need heavy speaker wire because the sub has an amp in it.
ddawg16 is online now   Reply With Quote
Old 05-26-2013, 09:11 PM   #3
Challenge Everything!
Deja-vue's Avatar
Rewards Points: 157
If your Subwoofer is non-powered and only has speaker-connections, I would definitely buy a new Subwoofer as well.
Today's Subwoofers have Amps built-in and just need a single LFE (Low Frequency Effect) connection from the Receiver, using a single RCA Cable.
Or, as suggested, make your own using simple RG6 Cables with RCA Adapters on them.
Back in the 80's, we had some Subs that needed Speaker wire connections, and from there the Cables were connected to the left and right Front Speakers.
Ugh!
Time to upgrade.
You can get a decent Receiver with 3D, Ultra 4K, 7 Channels, etc. for about $500, and a very nice Sub for about $200-$300.
Also look for the DIY Subwoofer Kits on PartsExpress.com.
Very nice Stuff there.
Deja-vue is offline   Reply With Quote
Old 05-27-2013, 09:51 AM   #4
Rewards Points: 1,452
A non-powered subwoofer (speaker wire input terminals, no power cord of its own) will not work with the (line level) RCA plug output from the A/V receiver even if you fashion a cord that connects the two.
For a receiver with line level subwoofer output you can hook up a separate (single channel many watt) amplifier to operate a non-powered sub. An RCA plug cable goes from the receiver to the separate amp and speaker wire goes from the separate amp to the sub.
One of the regular channel receiver speaker outputs can be commandeered to feed a non-powered sub. But that channel usually can't double as feeding the appropriate left or right or rear channel speaker since balancing the sound level for the sub and the respective regular speaker is difficult. Very low frequency content is approximately the same for all channels (left, rear, etc.) but you would not want to commandeer either the front left or the front right to feed the subwoofer exclusively.
Old 05-27-2013, 11:25 AM   #5
Rewards Points: 224
really
Fix'n it is offline   Reply With Quote
Old 05-27-2013, 11:30 AM   #6
Rewards Points: 224
ok, i think the Op could be happy with 2 of these, "properly" placed in the room.
http://www.parts-express.com/pe/show...number=300-629
Old 05-27-2013, 12:13 PM   #7
Deja-vue's Avatar
Rewards Points: 157
Originally Posted by Fix'n it View Post
really
You have a problem with my Statement?
I have spent over a grand on my own Subwoofer, but some of the $200 Models sound very good in Beginners Setups.
Matter of fact, I sold a lot of these here from Parts-Express:
http://www.parts-express.com/pe/show...number=303-436
Old 05-27-2013, 01:37 PM   #8
Rewards Points: 224
i just want whom ever reads this, to know that "very nice Sub for about $200-$300' is very subjective.
i have 2 CCS SD12's in 6qf ported boxs powered by a ep2500. and i consider this to be "just starting" to be very nice.
some day, i would like 2 of these in largish ported boxs. with 2 mono'd ep2500's (i already have them)
http://www.parts-express.com/pe/show...number=293-666
do you work at PE ?
Old 05-27-2013, 02:38 PM   #9
Deja-vue's Avatar
Rewards Points: 157
do you work at PE ?
Of course not.
I own a Computer/Network Home Theater Consulting Company.
Old 05-27-2013, 08:48 PM   #10
Rewards Points: 224
lucky you. i bet you see some high end stuff
Old 05-28-2013, 04:21 PM   #11
Deja-vue's Avatar
Rewards Points: 157
Smile
Mr. Fix'n it:
Actually, I do see some very nice Systems (like the ones you see at AVSForum.com) but really, most People are fine with $3500-$5000 Systems. They don't want a Subwoofer the Size of a Refrigerator.
Like I mentioned before, I use the 15 Inch "Titanic" from PE and couldn't be happier. That Thing shakes the House.
And, between you and me, dual 18 Inchers isn't really what you'll see in average Home Theater Systems.
7 out of 10 Theaters I worked on are using 10 Inchers, from all kinds of manufacturers.
Speakers have to have the "WAF" (Wife-approved-Factor) built in.
I install more and more In wall Speakers, believe it or not. Wifey just doesn't play along with massive Towers anymore.
And In-wall speakers have come a long way in the last twenty years.
Again, the average Home Theater User/Beginner/Joe-six-pack I see to troubleshoot, uses a lot less Equipment than perhaps you and me.
I sell a lot of Pioneer Amps, but use the Elite Series myself. Hardly ever do I sell Elite Amps, you know why? They are too darn expensive!
This Summer, btw, I'll be upgrading my existing 7.1 to a 11.2 System.
It never ends....
Old 05-28-2013, 09:40 PM   #12
Rewards Points: 224
AVS and AUDIOHOLICS here. but its been a while. i have an elite reciever, XPA-3, SWANS 6.1 &c3 center
................... i gotta go, tornado coming right at us.
Old 05-28-2013, 09:57 PM   #13
retfr8flyr's Avatar
I built my H/T as a dedicated room for video and listening to music, so I didn't have to worry about the WAF. I have been very happy with mine for almost 12 years now. There have been some changes and upgrades over the years but the basic setup has remained the same.
retfr8flyr is offline   Reply With Quote
Old 05-28-2013, 10:02 PM   #14
Deja-vue's Avatar
Rewards Points: 157
i got to go, tornado coming right at us.
Gosh, I hope you are alright, Fix'n it!
Lucky You!
And since we're posting Systems, here is mine.
Not dedicated, but oh, well:
Old 05-28-2013, 10:17 PM   #15
Rewards Points: 224
i'm back, tornado petered out.
some ENERGY sides, that work well. and my diy subs. oh and this ....
screen up , just cause i found it first.
119" dalite hp2.8
this is in my condo, that i sold. this same system is in my house now, but does look as good, cause i am still fix'n up the place.
connecting hd tv to av receiver using arc and hdmi cable raghavan Electrical 7 05-22-2013 07:12 PM
PVC Water Main Supply to Copper Connection jdobbs Plumbing 11 02-07-2012 12:01 AM
Adding Direc TV receiver Oh-Fudge Home Theater 1 01-05-2012 10:52 AM
Receiver upgrade - Audio wiring question jpb007 Home Theater 3 03-05-2010 05:53 PM
Telephone Jack Connection Problem jogan Electrical 9 04-20-2009 07:10 AM
