Ready To Order DTV - Home Theater - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Home Theater
Old 05-31-2009, 02:12 PM   #1
Rewards Points: 528
Ready To Order DTV
I want to make sure the installer shows up with all of the proper equipment needed to receive high definition programming. I do not wish to get a DVR. I am looking at:
1-SWM Compatible Receivers either the H21 or H23.
2-DirecTV Slimline KaKu, 5 LNB and either the AT9 or AU9.
3-DirecTV PI-21 Power Inserter
4-SWM Power Supply.
Here are my intentions:
I want hd programming to one tv with a possible expansion to another tv in the future. Over 98% of my tv veiwing is in the living room
I have an existing two RG6 wire run from the roof and the wires I believe are ok. There is also a ground wire that runs along side both RG6 to a grounding block. One RG6 feed goes to the tv in the basement and the other goes to the living room tv. I also have a vhf-fm antenna mounted on the chimney which I intend to keep.
Now is any part of 3 or 4 not needed or is other equipment not listed needed. I just want to make sure the installer gives me the right equipment. Your Opinions Appreciated.
rjordan392 is offline   Reply With Quote
Old 05-31-2009, 09:54 PM   #2
Home Theater Guy
You do not need a SWM system. a basic AU-9 will be fine. They will use an H-23.
Greg C is offline   Reply With Quote
Septic Order coming from Shower Drain CherylB1216 Plumbing 1 03-15-2009 05:16 PM
Where can I order dual-pane glass? Leah Frances General DIY Discussions 7 12-16-2008 11:46 AM
Installing tile and wood- what order? red shoes Flooring 7 05-08-2008 05:34 PM
Need help with permit/city got a Stop Work Order. amdspitfire General DIY Discussions 39 02-07-2008 02:45 PM
New construction ready for roofing... MLO Roofing/Siding 2 11-03-2007 02:46 AM
