Questions Re: Mounting A TV To Metal Studs (yet Again) - Home Theater - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Home Theater
Old 06-16-2009, 08:30 PM   #1
Questions re: Mounting a TV to Metal Studs (yet again)
Hi all, I have the following TV:
http://www.bestbuy.com/site/olspage....=1218011400290
and the following mount:
http://www.crutchfield.com/p_051MT25...1.html?tp=1416
my questions are:
-where can I find detailed instructions on how to mount a TV to metal studs in my walls? I just need as much detail as possible.
-should I just have a professional do this, & if so how will I know he is doing it the right way. I don't trust the "Geek Squad" etc.
Thanks!!!
eis61374 is offline   Reply With Quote
Old 06-18-2009, 10:53 AM   #2
Home Theater Guy
It's not only he mounting, but running the wires in wall and power. No offense, but if you are asking these basic questions, hire a pro. Try www.cedia.net to find a qualified dealer. Also, do not be surprised when many of them are not in a rush to do this small job. Since they did not sell you the TV or mount, there is not much profit in the install. If you had posted your location, I may have been able to refer you to someone local had you posted your location, as I help run a website for custom integrators and know dealers all over the world.
Greg C is offline   Reply With Quote
Old 06-18-2009, 10:58 AM   #3
Thanks Greg, I will check out the web-site. I'm in NYC (Manhattan on the Upper East Side).
Plasma Mount into Metal Studs davewolfs Home Theater 24 05-21-2009 08:23 AM
Problen with hanging heavy draperies in sheetrock metal studs wall. Fixitgeorge Remodeling 1 04-11-2009 01:03 PM
Pre-hung door with metal studs gmainolfi Building & Construction 4 02-07-2009 08:42 PM
metal or wood studs? pwise Carpentry 7 01-21-2009 11:08 AM
How difficult is it to learn to use metal studs? YerDugliness Building & Construction 7 08-18-2008 06:59 PM
