Question About Wireless Router Close To TV - Home Theater - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Home Theater
Old 07-18-2011, 07:45 AM   #1
Question about wireless router close to TV
I hope this is the proper forum for my question. I have been using DSL for my internet from AT&T for a number of years, but I am thinking of switching to Comcast for my internet and phone. The best place to connect the cable modem would be at the point where the cable box for the TV is located. Would there be any interference problem if my wireless router is so close to the TV?
David
Jessidog is offline   Reply With Quote
Old 07-18-2011, 08:20 AM   #2
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
I think it would be fine, but don't forget you can simply use a longer ethernet cable between the modem and router if you need some extra distance.
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
The Following User Says Thank You to Mr Chips For This Useful Post:
Jessidog (07-18-2011)
Old 07-18-2011, 12:26 PM   #3
Rewards Points: 1,016
Plasma TV's do cause issues for devices that operate at much lower frequencies, but not a problem for WiFi frequencies. It should not cause any issue for the wireless router or the TV.
____________
Vince
Old 07-20-2011, 07:29 PM   #4
I have my wireless router mounted on the back wall of my home theater enclosure, it's about 2-3 feet from the tv and even closer to all the other electronics and it has no issues. I was actually very surprised at how strong the signal was throughout the house considering it is basically inside a wall in the basement.
cdnNick is offline   Reply With Quote
Old 07-22-2011, 08:04 AM   #5
tonystewart1's Avatar
The only thing I have seen TVs intefere with are IR remotes. Some TV will block those.
Make sure that the cable they hook your modem to has the least number of spliters attached to it.
A good cable guy will take a leg off the first splitter and run a dedicated line to the modem. I always did. You lose signal and gain noise at every splitter and to many in the line to the modem will cause you problems upon problems with a stable connection.
tonystewart1 is offline   Reply With Quote
wireless ? econdave PC Repairs & Upgrades 13 06-30-2009 06:52 AM
Larson Storm Door Won't Close Snowbird Building & Construction 13 03-03-2009 04:01 AM
wireless router problems JAVAMAN PC Repairs & Upgrades 11 12-20-2008 03:50 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
hrv question indep HVAC 3 07-17-2008 11:39 PM
