Projector Screen Color? - Home Theater - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Home Theater
Old 06-15-2015, 07:01 PM   #1
Rewards Points: 72
Projector screen color?
Hi, I'm going to buy my 1st 100" projector screen for the bedroom. We plan to watch TV and play video games on it. This is the projector I'm going to get http://www.amazon.com/gp/product/B00...dp_o_pd_nS_ttl
The problem is I don't know if I should get black or grey or white screen. Please help!
pl4eva is offline   Reply With Quote
Old 06-15-2015, 09:47 PM   #2
Rewards Points: 6,652
You are best to ask over at avsforum.com.
The Following User Says Thank You to gregzoll For This Useful Post:
Fix'n it (06-15-2015)
Old 06-16-2015, 06:36 PM   #3
Rewards Points: 1,458
Making some assumptions:
I would call for a white screen with a higher gain.
This is based on the fact that you will have the lights off, or dimmed quite a bit, and will be directly in front of the screen.
1. A gray screen is used when there will be more ambient light, as it helps increase contrast.
2. A low gain allows for a wider viewing angle, and that wouldn't seem to be needed.
A plus to using the higher gain, white screen, is that you can lower the output level of the projector and get a longer bulb life.
Something to keep in mind:
With that particular projector the distance from projector lens to screen needs to be 14.2 feet with a 100" screen, so you need to make sure you have the room size.
Hope this helps you with your decision.
ktkelly is offline   Reply With Quote
What color to paint kitchen cabinets? kimberland30 Interior Decorating 20 11-28-2015 04:33 PM
Base color coat sticking better then primer? konsole Painting 8 08-22-2012 07:12 AM
Choosing a Color Scheme For Your Room Micheal11 Interior Decorating 0 08-10-2012 11:03 PM
what to do about this color combination tuffluck Interior Decorating 5 01-03-2011 01:29 PM
what to do about this wall color tuffluck Painting 2 12-22-2010 11:43 AM
