Power Amp And Speaker Connnection - Home Theater - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Home Theater
Old 11-04-2011, 02:31 PM   #1
power amp and speaker connnection
I currently have a car stereo with a 12v power souce and it is hooked up to a 2100 watt power amp. I am trying to hook up five 8ohm speakers to the power amp. I breifly hooked up one speaker to the power amp and the sound was very faiint and with some distortion. Am i doing something wrong? Any suggestion?
campuzano is offline   Reply With Quote
Old 11-06-2011, 08:40 AM   #2
I'm not an expert, but here's an opinion any way.
Your car stereo is probably already amplified. You are passing the output from speaker wires into another power amp (are you?). That equals distortion. If you car stereo has a 'pass thru' like a pre-amp output, you'll need to take unamplified signal from it and then to power amp.
diyorpay is offline   Reply With Quote
Old 12-02-2011, 07:48 PM   #3
Rewards Points: 1,514
Try this.
What impedance are the speakers that go with with the car radio you are hooking up to the power amp? (Example 20 ohms or 8 ohms). Connect a resistor of that value across the two speaker wires at the same time those wires are connected to the input of the power amp. Skip this step if the connection from the car radio is a jack (low level output) as opposed to wire ends (speaker output).
Does the power amp also have a "volume" contro? Adjust both this control and the volume control on the car radio, starting low and a little at a time and back and forth, to see if the speaker on the power amp comes to life normally.
AllanJ is online now   Reply With Quote
