Possible Interference W/ Powerbridge Setup? - Home Theater - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Home Theater
Old 09-13-2011, 06:41 AM   #1
Rewards Points: 249
Possible interference w/ Powerbridge setup?
I am planning on purchasing a Samsung 55" LED TV in the next week or two. I am planning on installing a PowerBridge connection to hide the Power & A/V cables. My question is this : looking at the image/link below, if I were to mount this on my wall, and have a 6 foot run in the wall between the input/output, isn't there a potential for video interference since the power and video cables are run parallel so closely together?
I know they offer other solutions where the power and a/v panels are separate, and I could go that option if needed, this one is just a nicer looking install.
Durt Ferguson is offline   Reply With Quote
Old 09-14-2011, 12:57 PM   #2
My gut reaction is to be unconcerned about interference caused by power lines to digital signals (DVI, HDMI) or optical (SPDIF). If your intention is to use these cables to provide signals to/from your TV/input/output, I expect you will have no problems.
Analog signal cables are potentially susceptible to interference. This includes line-level audio and component or composite or S-video. Having said this, I mix signal cables and power cables all the time. Sometimes I notice problems. Most of the time I don't.
oberkc is offline   Reply With Quote
Old 09-14-2011, 01:36 PM   #3
Not a Noob or Boob
Run the power up on the left stud then over to the box, then run the signal along the right stud and then over to the box. Airing on the side of caution is never a bad decision. Oberkc is right, it usually is not a problem on short runs like this.
Rob1975 is offline   Reply With Quote
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 04:28 PM
Which generator Interlock setup should I use for my sub panel? homerb Electrical 2 05-10-2010 03:44 PM
TV interference when devices are turned on or off in the home - ideas? rightbryce Electrical 7 09-19-2009 11:43 AM
Detached garage setup - Switch loop setup jamiedolan Electrical 3 02-07-2009 12:08 PM
home theater setup cannouu Electrical 5 04-09-2008 06:01 AM
