Please Help! Connect Stereo To TV - Home Theater - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Home Theater
Old 07-19-2009, 10:24 AM   #1
Question
Please help! Connect stereo to TV
Hello fellow DIY'ers!
I am having trouble connecting my Samsung surround sound stereo to my 50" Samsung Flat screen. I have tried everything I know. The owners manual doesn't give specific directions on how to do this. Simpy put, what I'm trying to do is make it so that my volume/sound comes from the stereo and not the TV. Can anybody please give me some information. Thanks in advance
melaluca08 is offline   Reply With Quote
Old 07-19-2009, 10:28 AM   #2
What model tv and receiver?
jerryh3 is offline   Reply With Quote
Old 07-19-2009, 11:10 AM   #3
Jerry, the model# for the TV is: HP-S5053
Model code# for TV is" HPS5053X/XAA
Stereo/Home Theater model# is HT-DS610
Both are Samsung Brand. The stereo works fine when playing a CD, all speakers are working. I just cannot figure out how to get the home theater speakers to work when I am watching regular cable TV.
It works when watching a DVD, etc..
Thanks!
Old 07-19-2009, 11:19 AM   #4
Are you using a cable box or does the cable go right into the tv?
Old 07-19-2009, 11:28 AM   #5
It looks like the tv has an optical audio output. You'll need to get an optical digital audio cable and connect that output to the optical digital input of the HT box. Or, if you're using a cable box check to see what kind of audio outputs it has and connect that to the HT.
Old 07-19-2009, 11:51 AM   #6
I'm using a Motorola cable box model# DCT-6416
Old 07-19-2009, 01:10 PM   #7
That box should have both composite and optical digital out. Use the optical output and connect it to the HT box.
Old 07-23-2009, 10:13 PM   #8
MT Stringer's Avatar
Rewards Points: 200
I had to check my setup...
Comcast Scientific Atlanta Explorer 4250 HDC high definition cable box connected to a Yamaha RX V-663 Audio Receiver via HDMI cable.
Receiver is connected to a 46 inch Samsung flat screen via HDMI cable. I have the receiver set on 7 ch enhancer. Everything works OK. Sound comes out of all five speakers + subwoofer.
I just went into the TV menu and turned the onboard speakers off.
I also have a Sony BDP S550 Blu Ray player and a Toshiba DVD/VHS combo that are connected to the receiver via cables.
A Harmony One remote control operates everything.
Hope this helps. I'd dig a little deeper but I don't want to disturb any of the cabling! :-)
Mike
MT Stringer is offline   Reply With Quote
Old 07-23-2009, 11:31 PM   #9
Rewards Points: 150
Right your TV is merely a monitor in this case. It does not produce sound output... your cable box is what produces sound TO the TV.
So, on your TV you can go into the menu and turn the speakers off and set it to "fixed output"
Connect from the cable box via optical cable or a digital coax (I prefer this as ANY RCA style wire will work, its digital so it will sound fine) to your home theater system. The connection will have a number.
You need to go into the settings on the home theater system and select the digital input for that channel.. you need to tell it connection 1 for instance, is receiving its source from a fiber one.
You'll have to do this as well with your DVD player for audio.
Most decent stereos include video switching as well, so you don't have to mess with the TV ever to change the video input
hope it helps. it's really not that hard.
johnnyboy is offline   Reply With Quote
Home Electrical / Car Stereo Question pjpjpjpj Electrical 4 08-12-2012 07:59 PM
How to connect switch to GFCI breaker? firemanter Electrical 3 10-28-2008 08:46 PM
How to connect a Digital Thermostat jfgagnon Electrical 2 05-10-2007 01:01 PM
Adding a phone line to an older connect point cramsmith General DIY Discussions 3 11-23-2005 12:35 PM
