-   Home Theater (http://www.diychatroom.com/f12/)
-   -   pc too hdtv (http://www.diychatroom.com/f12/pc-too-hdtv-15621/)
heavyduty 01-14-2008 10:40 PM
pc too hdtv
Looking to hook up a computer to a panasonic hdtv plasma with hdmi inputs but no dvi inputs. the computer is about 50 feet away from tv. any suggestions.
maverick214 01-14-2008 11:02 PM
I'm assuming your pc has DVI out and the TV has HDMI. You will need an DVI to HDMI cable. Check out monoprice.com. They have them for cheap.
heavyduty 01-15-2008 01:41 PM
will this carry the signal the 50 plus feet? Will this also carrry the audio?
jerryh3 01-15-2008 03:27 PM
Maybe, you'll have to buy a high quality cable to go 50 feet. Audio, no. Check out http://www.bluejeanscable.com/store/...bles/index.htm
gregzoll 01-20-2008 06:24 PM
Check out RapidRun @ http://www.rapidrun.com Radio Shack & also http://www.partsexpress.com sells the cables & units.
robdville 01-21-2008 12:06 AM
Go back to Monoprice -I can vouch for a 25' HDMI (setup that way in my theater)
Additionally, they have repeaters if you want to over do it :-)
http://www.monoprice.com/products/pr...seq=1&format=2
heavyduty 01-21-2008 04:06 PM
I've the cables ordered and will let you know how it goes.
jerome8283 01-29-2008 09:09 PM
I hope you have a quality graphic card that supports HD?
papajohn 02-26-2008 12:06 PM
PC DVI/HDMI to HDTV
The Panasonic HDTV are rock solid and I too have connected HD sources and a HD video card to the HDTV.
The video card I have is a ATI 2600. The connector is a DVI "looking' connector, but it functions like HDMI ( carries audio and video).
So I go with the ATI video card.
I have everything connected to a HDMI switch.
This allows me to have all the sources available to the Panasonic and then just run 1 long HDMI cable to the HDTV.
Then run a 25ft HDMI cable to my HDTV. I also have the Audio Optical cables routed thru the HDMI switch then to the Surround system so I can have surround sound for movies. I generally use the HDTV speakers for day to day news/ and sports.
Taipans 02-26-2008 01:43 PM
How does your ATI output video and audio over the DVI hookup? :huh:
gregzoll 02-26-2008 06:10 PM
The 2600 has a HDMI & DVI connector.
http://ati.amd.com/products/Radeonhd2600/index.html
jerome8283 02-26-2008 09:23 PM
The connector is a DVI to HDMI connector that I believe is capable of carrying audio and video. ATI and Nivda are the two leaders in the industry for this.
ATI has new cards that just came out, the 3450 and 3650. The 2900 is the older but very capable model.
Nivda has the 8x series which are just as good.
gregzoll 02-26-2008 09:26 PM
DVI or Digital Video Input, is incapable of carrying Audio. Where as HDMI or High Definition Multi-media Input is capable. In order to carry audio, you need a set of cables. Also, BTW, a Video card is not a Sound card, so there would not be any audio coming from it.
jerome8283 02-26-2008 10:15 PM
http://www.guru3d.com/article/Videocards/472/3
Taipans 02-27-2008 06:42 AM
This is what is throwing me. I have never seen a video card carry an audio signal? I have two 8800 GTX's running SLI in my system and they have no audio capabilities. Is this something only AIT cards like the old AIW have? I remember those back in the day and they had TV tuners built into them.
